Plug for turn signal hole in SB strut cover?
Old 01-28-2007, 03:35 PM
boogiewithtuck's Avatar
boogiewithtuck
boogiewithtuck is offline
Default Plug for turn signal hole in SB strut cover?
Moved my signals when I 1st purchased my '06 Bob last year (had the laydown plate/ signal mount from previous ride). At that time, in typical Mo Co fashion, no plug/cover was avalible for the hole left from the signal post.
Have since coated the covers and would like to fill the void. Realize if I wasn't so cheap I could have had the hole permanently welded/filled before they were coated. Now that the model has been out for 2 years, am hoping something is avalible.
Pics are not the greatest - one arm in a sling for 4 more weeks...
[IMG]local://upfiles/11891/8813790441C948009BE1F79AE2298397.jpg[/IMG]
[IMG]local://upfiles/11891/65527B6B49C34AF796FC5F89A879C7E7.jpg[/IMG]
Old 01-28-2007, 03:54 PM
bobcowan's Avatar
bobcowan
bobcowan is offline
Default RE: Plug for turn signal hole in SB strut cover?
The quick detach kit comes with a chromed plate to cover that oval void. If you're handy with a hacksaw and a file, you could just make one out of 1/8" aluminum stock.
Old 01-28-2007, 05:06 PM
but Ill try 2 try's Avatar
but Ill try 2 try
but Ill try 2 try is offline
I think Psycho did something about this problem on his bike. I have the same issue right now and haven't found anything to fit. Even Lowe's sells chrome plug, but of course the hole is oval like you said. Hurry up and find a fix and then let me know.
Old 01-28-2007, 06:36 PM
boogiewithtuck
ORIGINAL: bobcowan
That tells me that my ex-dealership (for service anyway) sold me the incorrect quick-deatch kit last year...no wonder the original bolts would'nt work! Sounds like I need to squeeze the parts counter guys for the plate @ no charge.
Thanks!
Old 01-29-2007, 04:37 AM
Sooee's Avatar
Sooee
Sooee is offline
It isactually a small cover that is part of the signal relocator component.
The quick detach kit on theDynas require the original signal assembly to be replaced with one that permits the detachableunit (sissy bar, whatever) to click into and the chrome cover is part of that.
sbon
06-04-2009 11:41 AM
Jor3lBR
07-16-2008 10:35 AM
vivid06streetbob
11-14-2007 03:44 PM
paisleysdaddy
08-02-2007 09:25 AM
blzbro
08-20-2006 11:04 AM
Quick Reply: Plug for turn signal hole in SB strut cover?
