hard pulling front brake lever
Old 09-23-2012, 02:12 PM
wayne schwedler's Avatar
wayne schwedler
wayne schwedler is offline
Stage IV
Unhappy hard pulling front brake lever
my 2010 Flhrp with anti lock brakes has a very hard to pull front brake laver when i first start it up it gets easier to pull after a few minutes
Help
Old 09-23-2012, 03:24 PM
scoobs's Avatar
scoobs
scoobs is offline
This was recently brought up with another members bike. Ended up being a valve stuck in the abs unit. Could still be an issue with the master cylinder or caliper though as well.
Old 05-15-2013, 10:40 AM
Dsarge's Avatar
Dsarge
Dsarge is offline
5th Gear
Default Just the Opposite
I realize this is an old thread, but I'm having just the opposite problem. I recently powder coated my levers and reinstalled them. Took a short ride to see if the new coating was thick enough to bind anywhere and it wasn't. No scratches within the housing at all from breaking use. Just the same, I dremmelled it down a bit near the pin. For some reason, my initial pull on the lever gives the normal amount of travel. The following pulls are very tight and short. The bike still breaks properly, but engages sooner like grabbing a handful of front break. I didn't do anything with the calibers, resouvoiur - just removed and reinstalled the lever. Have no idea what I did. Local Stealer just as mistified. Suggested I bring it in....heh.
Old 05-15-2013, 03:25 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,071 Likes on 2,555 Posts
So...are you going to take it in? And what the heck does "dremmelled" mean? I've never seen that word before. I know...look it up.
Old 05-15-2013, 05:32 PM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
if i had to guess i think he used a "Dremel" tool to clean out the holes.
Old 05-15-2013, 07:52 PM
Dsarge's Avatar
Dsarge
Dsarge is offline
5th Gear
Dremeled. Froggys right. I fat fingered my smart phone...
I'll take it in if I can't find any help here. Rode to work today and it stopped fine, just a little abrupt if Im not paying attention.
shodown220
01-11-2018 06:17 PM
01fatty
08-29-2011 10:44 AM
RK1
04-25-2011 12:12 PM
AusMongrel
10-31-2010 02:45 AM
rkgal
08-24-2009 03:05 PM
Quick Reply: hard pulling front brake lever
