Synthetic or Normal Oil in new 2012 dynas?
Old 09-17-2012, 06:23 PM
BKSinAZ's Avatar
BKSinAZ
BKSinAZ is offline
Default Synthetic or Normal Oil in new 2012 dynas?
I was just curious what is in new bikes upon purchase, synthetic or normal oil?.
Old 09-17-2012, 06:24 PM
1sicmofo's Avatar
1sicmofo
1sicmofo is offline
plain old crap unless its a cvo then it has syn-3 from the factory
Old 09-17-2012, 06:41 PM
ktrick01's Avatar
ktrick01
ktrick01 is offline
I don't know about the new ones but I run Screaming Eagle syn3 in my 96tc. It never uses any and seems to run cooler. I also don't worry about servicing every 2500 as I used to do with an 80 inch evo. The Dyna never uses or drops anything and go for 5000 without worry. The owner's manual recommends oil change at 5k so I don't worry about it. Just my thoughts. Enjoy your ride!
Ken
Old 09-17-2012, 07:17 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
The come with conventional.
Old 09-17-2012, 07:29 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
Full Synthetic if you can afford the extra expense. What convinced me is all the people that say "it isn't necessary". Even though I agree. With regular changes. Almost any spec grade oil will do. But that little bit extra never hurt anything.
Old 09-17-2012, 08:06 PM
Jaystn62's Avatar
Jaystn62
Jaystn62 is offline
Dealer put Syn 3 in mine at 1000 mile service and I'll keep on using a full synthetic. Maybe change brands...haven't decided yet.
Old 09-17-2012, 11:56 PM
montanimal333's Avatar
montanimal333
montanimal333 is offline
If you can afford a $15000+ bike you can afford a couple of twelve dollar quarts of oil when you service your bike... Stock bikes come with conventional except cvo's but nothing but i believe in synthetic.
Old 09-18-2012, 12:04 AM
Jaystn62's Avatar
Jaystn62
Jaystn62 is offline
+1 even though MOCO has made major improvements in last few decades....it's still aircooled...give it every advantage you can. It's just a few bucks and your personal hotrod.
Old 09-18-2012, 06:27 AM
wyldspirit's Avatar
wyldspirit
wyldspirit is offline
The OP wanted to know what the '12 models were shipped from the factory with.
They ship with Dino oil, not that said...
I changed over to Syn3 as soon as my 1000 mile service was due. Runs smooth as a kitten
Old 09-18-2012, 12:24 PM
blueridge's Avatar
blueridge
blueridge is offline
Spirit,
You put Synthetic in all three holes? I have bought Syn Amsoil 20-50W and going to put in all three holes as the manual recommends that. However I have the Severe Gear that I can use. not sure which I will use but I feel I should follow HD's recommendation and put same in all 3 holes.
I will have to get a couple ears to see if they notice any diff with Amsoil Syn 20-50 in the trans.
Quick Reply: Synthetic or Normal Oil in new 2012 dynas?
