Over rev engine
Old 09-03-2012, 05:33 PM
LDB415's Avatar
LDB415
LDB415 is offline
Question Over rev engine
Ok, so how do you know other than when it flies apart if you are over revving the engine since most models don't have a tach?
Old 09-03-2012, 05:35 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,537 Likes on 3,054 Posts
But all models have a rev limiter. It'll shut down a cylinder and you'll just think it blew up.
But it'll protect the motor.
Old 09-03-2012, 05:41 PM
FXD_TG's Avatar
FXD_TG
FXD_TG is offline
If you have a newer Harley with fuel injection then there's an RPM limiter that will cut off the fuel when the bike hits 5500 RPM. 5500 RPM is well below the actual redline.
The fuel will start to flow again when the engine rpm drops below 5500.
It's a pretty abrupt feeling and can be very disconcerting the first time you hit it.
Old 09-03-2012, 06:36 PM
sioux565's Avatar
sioux565
sioux565 is offline
Rev Limiter. End of story.
Old 09-03-2012, 09:18 PM
monkeyboy22's Avatar
monkeyboy22
monkeyboy22 is offline
Actually, the rev limiter is controlled by the ignition.
Old 09-03-2012, 09:29 PM
bwana1's Avatar
bwana1
bwana1 is offline
and the carbed models also have a rev limiter.
Bwana
Old 09-03-2012, 09:34 PM
rooti's Avatar
rooti
rooti is offline
better to ove rev then lug...Your good, enjoy
Old 09-03-2012, 09:38 PM
Foodog's Avatar
Foodog
Foodog is offline
My 09 Low Rider hits the rev limiter at 6200 rpm.
Old 09-03-2012, 10:01 PM
LDB415's Avatar
LDB415
LDB415 is offline
I don't ride hard at all and doubt I'll ever see the rev limiter but just wondered since there's no tach. I don't plan to lug the engine either and presume it will be apparent if/when that happens and a downshift will solve that.
baldric's Avatar
baldric
baldric is offline
Received 3,094 Likes on 649 Posts
Twin Cam will have oil coming from the air cleaner. Never done it myself but I heard somewhere..........
Quick Reply: Over rev engine
