High Idle Speed
Old 08-31-2012, 05:20 PM
Jaystn62's Avatar
Jaystn62
Jaystn62 is offline
Default High Idle Speed
I just tried to take my bike for a quick ride a few minutes ago. I stopped first to get a couple dollars gas just around the corner. When I started bike back up noticed it didn't want to idle down. Then check engine light came on. I waited a few seconds and light went out but was idling around 1400 rpm. I went ahead and took off decided to come back home. By the time I got home wouldn't go below 1740 rpm. I already have appointment for Tuesday to take bike in and have it looked at. Was just wondering if anyone else has experienced this on the newer Dynas or any of the newer Twincams.
Old 08-31-2012, 06:42 PM
AFMM3's Avatar
AFMM3
AFMM3 is offline
My Dyna twice has done just the opposite, idles so low it won't even run.
My Electra-Glide has the Fly-By-Wire throttle and the idle gets messed up at least twice on every cross country trip. The fix for that is to cycle the ignition on then off at least 4 times, ten seconds per cycle. This resets the idle by forcing the computer to forget what it has learned and start over.
It also seems to fix my 2008 Dvna idling problems.
Old 08-31-2012, 07:29 PM
Hitthespot's Avatar
Hitthespot
Hitthespot is offline
4th Gear
I had just the opposite problem also. New Super Glide Custom. Goes to normal fast idle when started, then went so low it quit. Only happened once, so I'm not too concerned at this point.
Old 08-31-2012, 07:32 PM
tech spec's Avatar
tech spec
tech spec is offline
Mine did it also. The idle control motor attached to the intake got gummed up by oil coming out of the breather. Remove your air cleaner, with engine running, spray a little throttle body cleaner into the intake . This has fixed the problem twice for me
Old 08-31-2012, 09:05 PM
nevil's Avatar
nevil
nevil is offline
If the check engine light came on it means you threw a code. Check your codes, maybe you can figure it out before Tuesday.
Old 08-31-2012, 10:29 PM
Dynaglide68's Avatar
Dynaglide68
Dynaglide68 is offline
" I started bike back up noticed it didn't want to idle down " Once in awhile they do that it's normal .....
Old 08-31-2012, 11:18 PM
wtb3886's Avatar
wtb3886
wtb3886 is offline
Try a search for DTC on here, there is a way to retrieve code faults that your computer has saved, then you will know what direction to take towards troubleshooting the real problem.
Old 08-31-2012, 11:39 PM
Jaystn62's Avatar
Jaystn62
Jaystn62 is offline
Thanks for the input guys but this bike has 3,800 miles and the check engine light does come on. Local dealer seemed more than happy to fix it under warranty so I'll let them deal with it. I do want a detailed explanation of what happened. Seems like a air or vacuum leak but I've never dealt with a FI bike. Will be a learning experience. Glad I'm not the first. Thanks again.
Old 09-01-2012, 04:22 AM
caaraa's Avatar
caaraa
caaraa is offline
WP50
18
09-22-2016 01:33 PM
midnitewolf
09-28-2010 02:03 AM
scuba biker
06-24-2010 12:51 PM
Ultraredone
Exhaust System Topics
10-02-2009 10:25 AM
skratch
06-03-2009 03:03 PM
Quick Reply: High Idle Speed
