Raising the Gas Tank
Old 08-29-2012, 10:39 AM
icebite1's Avatar
icebite1
icebite1 is offline
Default Raising the Gas Tank
I just installed this 1 1/2" tank lift and thought I would share some pics.What I liked the most is that I (wife) can clean the rockerboxes. Also there should be a little more heat escape/air flow for the top end.
The first pic is stock, the second is with the lifts installed on front only,the third is with the rear also lifted, and the forth shows being able to reach the top of the rockerboxes. Raising the rear didnt help a lot as far as cleaning but it sure didnt hurt to do it.
I got the lifts from our forum sponser, Kevin @ DK Customs.
Attached Thumbnails Raising the Gas Tank-img_0589.jpg   Raising the Gas Tank-img_0591.jpg   Raising the Gas Tank-img_0592.jpg   Raising the Gas Tank-img_0594.jpg
Old 08-29-2012, 12:47 PM
BigBill1's Avatar
BigBill1
BigBill1 is offline
The first pic is stock, the second is with the lifts installed,the third is with the rear also lifted, and the forth shows being able to reach the top of the rockerboxes. Raising the rear didnt help a lot as far as cleaning but it sure didnt hurt to do it.
Hard to install? How long? Did you have to take the tank off? It looks good. Thanks for the pics.
Old 08-29-2012, 01:11 PM
spider2's Avatar
spider2
spider2 is offline
How did it affect the seat position?
Old 08-29-2012, 01:42 PM
msocko3's Avatar
msocko3
msocko3 is offline
If my dad sees this I may have some more work to do this winter.
Old 08-29-2012, 02:49 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,082 Likes on 3,484 Posts
Now back for the crotch coolers ! Works and looks great, but it leaves a nice gap above the heat shield. A large leather crotch cooler is in order here I think !
Old 08-29-2012, 03:14 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
It'll keep you out of trouble. You must remember you won't have anything to do to your Gold Wing. You know the saying" Busy Hands Are Happy Hands"
Old 08-29-2012, 03:21 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
FLTR2008TRIKE is offline
Thumbs up
Originally Posted by oldmsocko
it'll keep you out of trouble. You must remember you won't have anything to do to your gold wing. You know the saying" busy hands are happy hands"
lol....
Old 08-29-2012, 08:29 PM
icebite1's Avatar
icebite1
icebite1 is offline
Takes less than an hour.
Remove the seat, loosen the two front tank bolts, remove the two rear tank bolts and install rear lifts if you are doing them also otherwise just loosen the bolts. Now remove the front bolts and install the front lifts. Tighten everything down and replace the seat. All done.
No difference in seat height but if you are raising the rear also as I did then the nose of the seat is up about 1" as you may be able to see in the pics. You cant notice it unless you are down looking straight across such as where i took the pics. I didnt notice any different feel in the seat when I sat on it.
If you do the rear lifts also put the rear spacers in befor you remove the front bolts.
Old 08-30-2012, 07:44 AM
icebite1's Avatar
icebite1
icebite1 is offline
I will check out the Crotch coolers, the '07 RK I just got doesnt have the heat shields ,I already installed them on my other RK, so I can move the TG shields to my RK and use the larger C Coolers on her TG. If I go that way ill post a pic.
Old 08-30-2012, 01:07 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 3,940 Likes on 2,295 Posts
Glad you're liking them.
Next time you are out on a ride, see if you notice any difference in the air coming up over the top front of the tank.
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Quick Reply: Raising the Gas Tank
