FM TW-222 Cam reviews needed
I want their dyno to do my bike, it is amazing how their numbers are so much higher than every one else. My 2011 road glide ultra with Boyesen power x intake, V&H power duals, PC-V with auto tune, and Andrews 54H cams on Robs dyno can ONLY achieve 87 hp and 92 lb ft torque and yet even without cams theirs can reach above 100. In lieu of discussion mine were done at 100* and the bike runs better than the #'s indicate. Thank God we don't ride dyno sheets.
Actually, I'd like to see some comparision to the TW-222 and the TW5-6 cam that woods makes. It kind of looks like you're splitting hairs between the two cams.[/QUOTE]
Me too, I called and talked to Bob last week about cams. My bike is a 2011 Limited and I want it to pull as soon as I let the clutch out... He said the 222 is the deal so we'll see soon enough.
Lots of dishonesty out there. I'd not be surprised if the numbers presented were a touch higher then realistic for any build. They would be able to say there was a margine of expectation and your bike came up on the low side rather than the high side of that range. After all what proof have they offered that those numbers are consistently reachable? I hope it works out for you, but just because they boast higher then industry numbers does not mean much. I'd challenge that a bit to see why the industry does not share their success before I started buying that claim.
Nothing odd about it. Lot's of cams are built with these similar specs. Makes for a great all around midrange cam. You'd see similar cams in stock TC's if Harley didn't have to deal with the EPA.
I'd say the 222 would fit your needs nicely.
Received 69,945 Likes
They initiated the catalytic converter move, but thought/said to the EPA that all of the other motorcycle manufacturers had to follow suite.
This is according to an HD dealer.
Actually, it is HD that is pro-active and voluntarily goes for the EPA bullshit, and spoon-feeds it to us.
As far as the numbers we publish some need to take into consideration that we have spent years, many bikes, many components, and thousands of dyno runs developing specific combinations to come up with what we consider the best of the best of our testing and everything is relative to our dyno and conditions for that day.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
