What's needed to add a 21" front wheel/tire on my bike?
Old 08-10-2012, 10:37 PM
cpita's Avatar
cpita
cpita is offline
Default What's needed to add a 21" front wheel/tire on my bike?
Besides the wheel and tire LOL!
Old 08-11-2012, 05:35 AM
Houston_t's Avatar
Houston_t
Houston_t is offline
Nothing, but consider swapping out your rotors to a nice chrome set to match the new wheels.
Old 08-11-2012, 05:38 AM
r8rs4lf's Avatar
r8rs4lf
r8rs4lf is offline
Old 08-11-2012, 06:13 AM
Landbeasts's Avatar
Landbeasts
Landbeasts is offline
Make sure the rims come with bearings, etc. If your going thru a retailer, just talk to them. Make sure your axle size is right. You shouldn't need to change your front fender with a 21 inch rim. But you might want to, just to show off the rim. Also may want to consider dropping your front end an inch or two to get the bike back to ride height.
Old 08-11-2012, 06:54 AM
DuraGlide's Avatar
DuraGlide
DuraGlide is offline
Some people have had issues with the 21 tire rubbing the fender and scorching the paint. It's a good idea to drill out the 2 rear fender mounting holes to 3/8 and lift up on the rear of the fender when tightening the bolts. Then tape a 5/16 nut to the 21 tire and spin it to check clearance. Will you be happy with a 21 front and a stock rear? That could add to the cost if you are like me. Stock rear wheel sticks out like a turd in a punch bowl.
Old 08-11-2012, 07:07 AM
scj's Avatar
scj
scj is offline
The Avon 120/70/21 is a lower profile than what Metzler offers and will not rub your fender if you drill out the rear two holes to 3/8" and rock the fender forward (pick up on the back/bottom side of it) as you tighten it down.
If you have ABS, you need the correct front left wheel bearing.
OOgoon
Wheels/Tires
06-20-2014 12:13 PM
gilmour68
02-18-2013 07:41 PM
FattyMcDeuceter
05-02-2008 05:18 AM
melancon2008
04-23-2008 07:03 AM
2006streetglide
10-05-2006 09:07 PM
Quick Reply: What's needed to add a 21" front wheel/tire on my bike?
