Low Voltage????????????????????????
Old 07-24-2012, 11:41 AM
mwriggs's Avatar
mwriggs
mwriggs is offline
Default Low Voltage????????????????????????
I put a new HD Voltage Regulator on my EGC last night as the volt gauge was pegged out, suggesting that the VR was bad. Now the gauge reads 12 volts straight up, no more no less, and I m getting a check engine light, and a battery light. The codes that pop up , are low voltage.........
Could it be the battery is worn out?
Could it be the Stator is going bad?
What are the symptoms of a bad stator?
Old 07-24-2012, 11:47 AM
Sam2010's Avatar
Sam2010
Sam2010 is offline
I was told once by a old parts guy. That when a voltage reg. Goes out it can take out a good battery. I bet you need a new battery.
Old 07-24-2012, 12:15 PM
grbrown's Avatar
grbrown
grbrown is offline
Wink
You need a multi-meter and to do a number of simple checks, like what's coming out of the alternator, regulator, etc. You can easily isolate what the problem is. There are some Stickies on checking your charging system here.
Old 07-24-2012, 12:20 PM
frog13's Avatar
frog13
frog13 is offline
Can't diagnose from the volt gauge, probably is, but may not have been the regulator. Beginning to look like you are getting the 12 volts from the battery and no charging going on .... check the voltage on the battery at idle and then at 2500 RPMs, it should increase significantly. If not, pull the regulator and check the AC voltage from the alternator system. You will know right away what is bad ....
Old 07-25-2012, 09:58 AM
mwriggs's Avatar
mwriggs
mwriggs is offline
While running, the volts coming from the battery were less than 12 , so I am going to get a stator and put it in. No charging going on at all.......
Old 07-25-2012, 10:07 AM
smithbrl's Avatar
smithbrl
smithbrl is offline
You may want to check input to the regulator, still. The new regulator may be bad also. Not probable but possible.
Old 07-25-2012, 10:19 AM
grbrown's Avatar
grbrown
grbrown is offline
Exclamation
What did you measure that voltage with? The voltmeter on your bike is not suitable for doing checks. Have you done a detailed check, as per the link I posted? Don't go replacing stuff if you are not confident it needs replacement.
Old 07-25-2012, 11:37 AM
frog13's Avatar
frog13
frog13 is offline
AGAIN!!! A few minutes of time, you might learn something new and SAVE A LOT OF MONEY! Plus, why rip into the primary if you might not have to? You came on here asking for advice, got excellent advice and yet you choose to dismiss it?
Old 07-25-2012, 11:41 AM
mwriggs's Avatar
mwriggs
mwriggs is offline
I didnt ignore yalls advice, I had a friend check everything with his volt meter.......Should have said that earlier.......
Billf
01-10-2023 11:27 AM
chrome-dome-dave
10-05-2016 08:36 PM
FlamedFXR
03-29-2016 06:17 PM
Kytann
08-15-2013 06:21 PM
Astro
10-10-2010 07:08 PM
Quick Reply: Low Voltage????????????????????????
