Stock seat
Old 07-15-2012, 08:49 AM
jagsfan811's Avatar
jagsfan811
jagsfan811 is offline
Default Stock seat
So I feel very dumb in asking this but I searched all over and unless I was using poor searching parameters I couldn't find the answer. I took off my 2-up seat to put the stock solo seat back and to my surprise instead of a threaded hole on the fender it's a keyed slot. How do I connect the solo seat? Thank you
Old 07-15-2012, 08:55 AM
grbrown's Avatar
grbrown
grbrown is offline
That slot takes a threaded fastener the same as the one you attached your 2-up seat to. You may even be able to swap it from one hole to the other (I've never tried!). Or buy a second one, so you can swap over easily.
Old 07-15-2012, 09:15 AM
jagsfan811's Avatar
jagsfan811
Awesome thank you!! I will try now
Old 07-15-2012, 09:24 AM
jagsfan811's Avatar
jagsfan811
Where can I find another threaded fastener?
Old 07-15-2012, 09:50 AM
whiskey girl's Avatar
whiskey girl
whiskey girl is offline
You can swap the fastener from the back slot to the front. Your dealer will have the fastener or you can order one online. They're cheap.
Use a bit of wire to get the fastener through the fender and hold it there while you slip the tab on. Easiest way to do it that I've found.
Old 07-15-2012, 10:05 AM
jagsfan811's Avatar
jagsfan811
I would prefer to buy a second one so I don't have to keep swapping back and forth. What are they called because I've done a couple google searches and can't seem to find the component. Much appreciated
Old 07-15-2012, 10:52 AM
SilverStride's Avatar
SilverStride
SilverStride is offline
I bought a Mustang seat and they had them on their site. The local bike shop here, not the dealer had them on the self. I would try a dealer or call around if you have shops around that sell parts.
Old 07-15-2012, 11:04 AM
modular's Avatar
modular
modular is offline
If you get a Mustang seat they include a new threaded mount with the seat. At least one came with my Vintage Solo.
Old 07-15-2012, 11:06 AM
Hazardous Smoker's Avatar
Hazardous Smoker
Hazardous Smoker is offline
Got one with mine as well.
whiskey girl
Ok here ya go. I have spares so went and looked.
HD part # 59768-97 fender/seat nut kit
This is the piece that goes through the fender
HD part # 2952A screw, sems truss head
This is just the screw to hold the seat on. I have one in my parts box but you can get something at the hardware store a LOT cheaper.
JP Cycles item # 8200095 seat mount nut $4.00
Quick Reply: Stock seat
