2001 883 oil leaking from primary breather tube.
Old 07-10-2012, 03:40 PM
classicmill's Avatar
classicmill
classicmill is offline
Stage I
Default 2001 883 oil leaking from primary breather tube.
My son recently bought a 2001 883, and he has been experiencing oil dripping out of the breather tube that runs from the primary up to behind the oil bag. We have changed the oil & filled to proper level, but still pushes out after about 20 miles of riding. Need some help here.
Old 07-10-2012, 04:40 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,631 Likes on 1,125 Posts
On my 1991, I get a tiny bit splashed on the swingarm, just behind the bushing. It's been doing it since I bought her new in November 1990. I've never really torn into it to find the source because it's so minor.
I think it's from the primary/transmission breather as well, because it's only when I ride that it happens. Might just be one of the bike's characteristics. If it's not happening when it sits, you may want to just leave it alone.
Good luck.
John
Old 07-23-2012, 09:40 AM
edgarbrbl's Avatar
edgarbrbl
edgarbrbl is offline
Stage I
Check this to my friend turned me
SERVICE BULLETIN Harley Davidson July 28, 2000
http://www.techbill.net/Harley/docs/M1103.pdf
Old 07-23-2012, 09:57 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
The tube is intended to sit high. Where does he have it located ... possibly too low?
Old 07-23-2012, 10:20 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
This. If it is routed low (especially if it is lower than the inlet to the case) it will be very easy for the oil to drip/spray out. It should be routed up around the back of the oil tank. The older models actually vented into the tank. Just zip tie it up with no big bends/kinks in the line and you should be good.
Old 07-23-2012, 10:31 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
What Scuba said. Mine was actually flopping around with removal of the rear fender. As you can see in this pic, I ran it to the side and installed a breather filter.
Attached Thumbnails 2001 883 oil leaking from primary breather tube.-vent.jpg
Jimmyacorn1
Shovelhead
07-08-2014 06:20 PM
Dana Phelps
02-13-2013 07:25 AM
IRONCAM
Oil Archive (no new posts)
09-15-2010 08:01 PM
bikerlaw
EVO
01-17-2010 10:35 AM
racedvl
10-02-2005 11:03 AM
Quick Reply: 2001 883 oil leaking from primary breather tube.
