rear lowering blocks?
Old 07-06-2012, 01:51 PM
xracer110's Avatar
xracer110
xracer110 is offline
Default rear lowering blocks?
are lowering blocks any good or is it the half/*** way of dropin the rear? or just buy shorter shocks. Also if the back is dropped 1-11/2 inches does this affect the kick stand or any thing else? I have a 2010 wg.
Old 07-06-2012, 02:13 PM
Spyder_63703's Avatar
Spyder_63703
Spyder_63703 is offline
It doesn't look bad but rides rougher. You will need a shorter kick stand.
I would get the shorter shocks. I used the lowering blocks before I swapped shocks.
Old 07-06-2012, 02:17 PM
stuartb01's Avatar
stuartb01
stuartb01 is offline
Default Rear lowering blocks
I used the blocks because of my short-a$$ legs! I did have to adjust the shocks to smooth out the ride a little. Easy to install and affordable.
Stu
'06 FXDI
tcabello's Avatar
tcabello
tcabello is offline
ok at best...changes the geometry of the shocks making them less effective and oem shocks aren't that good to begin with...I'm running 1" lowering blocks on my 'bob, but I have every intention of buying a burly slammer kit...some day...soon...I hope...
Old 07-06-2012, 02:18 PM
ynots's Avatar
ynots
ynots is offline
I haven't lowered mine but it seems to me that with the lowering blocks you wouldn't be sacrificing any travel in your suspension.
Old 07-06-2012, 02:36 PM
WG2011's Avatar
WG2011
WG2011 is offline
I was going to do the blocks and ended up buying shocks I dropped my 2011 WG 1" only in the rear and the kick stand is fine. The blocks a re cheap way to lower but seem to have some quirks for some people thats why I went with shocks and I am glad I did. You can get decent (not top of the line) shorter shocks for 200 bucks.
Old 07-06-2012, 03:36 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
Lowering blocks are subjective, they work in a pinch. Although, you are better off going with different sized shocks.
Shocks are affixed at two fastening points, giving you a solid foundation to the swing arm.
Lowering blocks are able to loosen up and pivot on there mounting point, which in turn can and will cause slop in rear suspension dynamics. Let alone cause some pounding on the swing arm itself, which can cause fractures in the material of the swing-arm.
Search the web, as there are pictures of the damage done by these blocks.
I tried them for about 2 months to make sure I really wanted my rear-end lowered, then I went with Burley<sp> brand shorter shocks for a permanent modification.
I ended up giving the blocks away to someone here on the forum, so he too could try them and see if he also liked the function of a lowered rear-ended suspension.
Too each their own, just remember, that band-aids are just that. They are temporary and not permanent modifications.
Old 07-06-2012, 05:28 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I ran them. They do just what they are advertised to do. Good shocks work better than stock socks with lowering blocks, but for the price they are hard to beat.
Old 07-06-2012, 06:07 PM
georgy51's Avatar
georgy51
georgy51 is offline
I run 1.75" lowering blocks ,I have no issue, does run a little rougher , but I like the angle it gives the shockers
Attached Thumbnails rear lowering blocks?-imag0062.jpg   rear lowering blocks?-imag0077.jpg
Rollon
05-30-2019 08:34 PM
bub 270
04-16-2011 06:30 PM
Dunkon76
03-11-2011 01:12 PM
Lorance66
11-24-2008 03:55 AM
ziggymotion
09-21-2007 08:53 PM
Quick Reply: rear lowering blocks?
