Rear axel stuck
Old 06-05-2012, 09:17 PM
Flintshooter54's Avatar
Flintshooter54
Flintshooter54 is offline
Default Rear axel stuck
Changing tires tonight. Well taking the wheels off and taking them into the dealer to have new tires mounted and balanced. This is the first time the rear wheel has been off this 2010 Limited. Has about 16,000 miles and still had a few left but wanted new rubber and I will replace brakes too before a trip I have coming up shortly. That rear axle was stuck. Did everything exactly like the shop manual said but when I finally got it out using a brass 5/8 rod as a drift with a bigger hammer than I am comfortable with on my baby. The center of the axle was corroded. Had to chuck it up in my lathe and spin it with steel wool and WD40 before I could get it to slide back through the wheel by hand. Definitly no antiseese or grease on that one. Is this a common issue? Not heard of any problems before. I just hope the anti lock sensor did not get hurt. It was stuck pretty good too. Bearings seem smooth with no play or rough spots.
The front axle came right out but the right bearing in the front wheel it rough. Those will get replaced. Only 16K
Old 06-05-2012, 09:55 PM
davessworks's Avatar
davessworks
davessworks is offline
Oh joy - something to look forward to. I'm at almost exactly the same mileage. Same wear. Same color bike etc. etc.
Old 06-05-2012, 10:21 PM
FFHD05's Avatar
FFHD05
FFHD05 is offline
i went throught the same thing changing my rear out on my 11 @10k miles..yea heavy right wrist but i just cleaned it up and put a nice coating of anti seize and all was good i was nervous too as the manual acts like it will slide right out...
Old 06-05-2012, 10:31 PM
iwillfixthem4u's Avatar
iwillfixthem4u
iwillfixthem4u is offline
The manual calls for silver antiseese to be applied also with the brakes removed check your wheel bearings
Jackpoticorn
05-03-2017 09:16 AM
Mojo7
03-20-2017 02:21 PM
Snipman
EVO
12-05-2015 03:50 PM
blackflame
09-11-2013 02:49 PM
sutphen30
03-22-2009 06:55 PM
Quick Reply: Rear axel stuck
