Codes b1121 and b1122
Old 05-29-2012, 04:52 AM
saxmanwizard's Avatar
saxmanwizard
saxmanwizard is offline
1st Gear
Default Codes b1121 and b1122
Ive taken my 01 softail to the tech and I have fault codes B1121 and B1122, which are
B1121(TSM) Left Turn Output Fault
B1122(TSM) Right Turn Output Fault
all the bulbs are working so I can only think there is a short to ground ,is this correct ???, or is there something else causing this problem , when I use thr indicators they flash normal for 4 seconds the flash at a more rapid pace , I am lost on what is causing this and where to start..any help would be grateful , Cheers.
Old 05-29-2012, 07:00 AM
Rakthi's Avatar
Rakthi
Rakthi is offline
Looking at my 2009 electrical manual ... I know not really the same codes because according to my manual b1121 and b1122 are "will not flash"
What they mention first is to check for corrosion/bad contacts among the terminals and bulbs, clean them and apply electrical contact lubricant ...
Do they still auto-cancel after 20 something flashes when you are riding? If they don't is indication of TSM module on the way out ...
Guess you need to get your hands on a 2001 electrical manual.
Old 06-25-2012, 05:35 PM
ek071391's Avatar
ek071391
ek071391 is offline
Stage I
Did you just switch to LED turn signals by the way? I did and I am getting the same error with the red key. I ordered a Load Equalizer from Kuryakyn, should solve my problem.
Old 06-25-2012, 06:35 PM
jakazz's Avatar
jakazz
jakazz is offline
yup my first tought
Old 09-02-2017, 08:16 AM
Kiwi6001's Avatar
Kiwi6001
Kiwi6001 is offline
1st Gear
Default I have these fault codes aswell
so I have these fault codes I've changed the indicators but I changed to bulb indicators and they seem to flash normally for 4 seconds and then really fast I'm not too sure what to do. Do I need to get different bulbs the original indicators were bulbed indicators
Old 11-05-2021, 07:35 PM
Beast56's Avatar
Beast56
Beast56 is offline
Stage IV
I'm havinf the same issue. Just switched out rear fender for CVO fender with the led lights. After connect turned on and got 4 seconds if normal flashing on turn signals then rapid blinking. Same codes pop up. I cleared the codes and unplugged the rear lights and front lights but codes come back when I use the blinker. I even bought a bad lands illuminator and connected it but rear lights didn't work when plugged in. Any suggestions?
Old 11-06-2021, 10:59 AM
slickman's Avatar
slickman
slickman is offline
You need to install resistors in line or have LED's that have that built in. It's called hyper flash
DrewBone
08-25-2014 10:25 PM
Jake911
03-21-2013 04:14 PM
1HarleyGuy1
08-16-2010 05:47 AM
HOGRIDA_06
05-10-2009 04:09 PM
Max Iron
04-26-2007 10:05 PM
Quick Reply: Codes b1121 and b1122
