dumb electrical question on flasher
Old 05-26-2012, 10:57 PM
Reaper_ggy's Avatar
Reaper_ggy
Reaper_ggy is offline
Default dumb electrical question on flasher
Ok so basically when the bike runs the flashers are lit as running lights,
my right flasher doesnt, but it does flash when I ask him to do so.
So is it a short ?
Old 05-27-2012, 12:08 AM
ynots's Avatar
ynots
ynots is offline
Are you running the Aux. running Lt./ brake Lt / turn signal conversion kit or are the signal/running light you described come factory on the wg? If so maybe the kit is the problem?
Old 05-27-2012, 12:31 AM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
its a 2 way bulb like an 1157 ....half of its burnt out
Old 05-27-2012, 05:06 PM
Reaper_ggy's Avatar
Reaper_ggy
Didnt tought it was possible I'll check that ... after looking on the entire bike hahaha,
thanks !
Old 05-27-2012, 07:14 PM
HeyYou's Avatar
HeyYou
HeyYou is offline
A short means you are attempting to put 12V directly to ground; ergo you are putting out maximum battery amperage through some wire.
So, a short = blown fuse.
If there is no fuse to blow, then a short = call the fire department because your bike is on fire
IMKMA
2014-2023 Touring Models
08-02-2014 08:59 AM
Gordon65
07-13-2011 07:25 PM
oneshotdog
04-21-2011 10:32 PM
capt42a
11-02-2005 10:49 PM
Quick Reply: dumb electrical question on flasher
