Suicide clutch
Old 05-26-2012, 12:13 PM
chicanagirl's Avatar
chicanagirl
chicanagirl is offline
Default Suicide clutch
I know old Indians, and i think old HDs to, have the suicide clutch. I asked an old timer why its called that, he says cause if you use it wrong it will flip you over backwards. At highway speeds that equals death. That makes me afraid to ride it and i've been riding for a while. Anyone ever rode an oldie with the suicide clutch?
Old 05-26-2012, 12:57 PM
firefighter616's Avatar
firefighter616
firefighter616 is offline
Really they were called that was because (the I know betters will be in shortly) you had to shift with one hand, clutch and release with a foot and break and throttle with the other hand.and foot... on a hill it was a PITA..... definitely a hand/eye/foot/hand coordination thing..... hence suicide shift.
I will be proven wrong in a matter of hours, TIA
Old 05-26-2012, 01:10 PM
Stash905's Avatar
Stash905
Stash905 is offline
The old timer is full of ****. Flip you over bacwards?
Old 05-26-2012, 01:11 PM
foulplay's Avatar
foulplay
foulplay is offline
Suicide clutch got the name because if a rider couldn't find neutral and he lost balance his foot would come off the clutch causing his scooter to jump into traffic.
Old 05-26-2012, 01:43 PM
JohnFlorida's Avatar
JohnFlorida
JohnFlorida is offline
flip over backwards ? thats funny . Maybe he's thinking about a "suicide kick start"
Old 05-26-2012, 01:46 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,547 Likes on 3,057 Posts
I had one of those! ( w/a magneto.)
Gimpy
Old 05-26-2012, 03:47 PM
Malum's Avatar
Malum
Malum is offline
Left foot clutch. Left hand on jockey shift. Right foot on brake. Right hand on throttle to keep the damn thing running and to steer.
Better find neutral fast coming to a stop at a signal/intersection or out you went into traffic.
Also factor in usually 1 or more false neutrals to keep you on your toes.
Old 05-26-2012, 03:54 PM
pococj's Avatar
pococj
pococj is offline
The old bikes had "rocker" clutches, not suicide clutches. The clutch pedal stayed where you put it, if the tension was set correctly.
Now, a rocker clutch could become a suicide if the tension was too loose. But even then it simply mimics a car clutch - pedal down & you're disengaged; pedal up & you're engaged.
Old 05-26-2012, 04:24 PM
oct1949's Avatar
oct1949
oct1949 is offline
Nope,, just the thought of having one Scarrred me...
Old 05-26-2012, 04:51 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
I like the idea, but starting on a hill with one terrifies me.
Quick Reply: Suicide clutch
