Cam chain tensioner on TC88
Old 05-25-2012, 09:19 PM
tracey87's Avatar
tracey87
tracey87 is offline
Default Cam chain tensioner on TC88
I saw this on Kendalls website and was wondering if anyone had tried something like it? Same part, just made of better material. These are only like 20 bucks. To install the hydraulic upgrade kit is like $800.
http://www.kendalljohnsoncustoms.com...458&product=29
This is the company that makes them, says $29
http://www.banditmachineworks.com/pd...n_adjuster.pdf
Old 05-25-2012, 09:32 PM
blackbear's Avatar
blackbear
blackbear is offline
Those ain't cam chain adjusters those are manual primary chain adjusters.
Old 05-25-2012, 09:39 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Those are just shoes. This is an automatic chain tensioner that doesn't cost $800
http://www.phatperformanceparts.com/...e=M6-TENSIONER
Old 05-25-2012, 10:47 PM
tracey87's Avatar
tracey87
tracey87 is offline
Ok, so does any body make the shoes that aren't made of the same material that will disintegrate like the oem ones?
Old 05-25-2012, 11:31 PM
rare100thHD's Avatar
rare100thHD
rare100thHD is offline
My 03 Road King that I sold to a buddy has over 70 thousand miles and has never had it replaced or has it ever disintrigrated. Must a had yours adjusted to tight.
Old 05-25-2012, 11:34 PM
Fishrrman's Avatar
Fishrrman
Fishrrman is offline
"Ok, so does any body make the shoes that aren't made of the same material that will disintegrate like the oem ones?"
I believe the answer to that question is "no".
You either replace the worn tensioners with new ones from HD (which will wear out again), or, you spring for the hydraulic tensioner upgrade.
If you've got tensioners that need replacing, or you're getting up there in miles and you suspect that they might need replacement soon, the best thing for the long-term health of the bike is to bite the bullet and get the hydraulic tensioner upgrade. Just one of those things for which there is no other alternative...
Old 05-26-2012, 05:09 AM
M&P340's Avatar
M&P340
M&P340 is offline
I think what you're thinking about are the Cyco polyamide tensioner friction insert replacement, here:
http://www.harleydavidsontensioner.com/
I've read that some guys have tried them, but haven't seen any reports of their longevity yet. Too new, only been available for a few months. Theoretically (based on the tech specs of the PA46 nylon) they should be slicker, last longer. But so far, the empirical evidence is a bit thin. I just replaced mine with OEM, or I would try them. Always up for hitch hiking home.
Old 05-26-2012, 08:02 AM
magna's Avatar
magna
magna is offline
If you've got tensioners that need replacing, or you're getting up there in miles and you suspect that they might need replacement soon, the best thing for the long-term health of the bike is to bite the bullet and get the hydraulic tensioner upgrade. Just one of those things for which there is no other alternative...[/QUOTE]
Be warned this isn't a complete cure as the Harley up grade still uses the original chain on the inner camm and it's the chains that cause the damage.
Old 05-26-2012, 09:00 AM
monkeyboy22's Avatar
monkeyboy22
monkeyboy22 is offline
Another choice is gear driven cams.
Old 05-26-2012, 09:38 AM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,511 Likes on 645 Posts
I dont think those will fit your cam chain......
Quick Reply: Cam chain tensioner on TC88
