How Hard To Replace Rear Brake Shoes On A Softail?
Old 05-23-2012, 08:05 PM
bjewell's Avatar
bjewell
bjewell is offline
Default How Hard To Replace Rear Brake Shoes On A Softail?
My '03 FXST's rear brake pads are down to the metal. Sac Harley wants @ $125 to replace them. Pads cost $55. Is this a job that can be done at home by the average guy with no special tools?
Old 05-23-2012, 08:26 PM
springer 03's Avatar
springer 03
springer 03 is offline
Do you have a service manual? That would be the place to start and @$50 it is a worthwhile investment. After looking at it, you can then gauge whether you can do it yourself.
Old 05-23-2012, 08:51 PM
tracey87's Avatar
tracey87
tracey87 is offline
I just did mine and all you need to do is remove the two pad pins and the pads come right out. Put the new ones in and tighten up pins. Removal of rear wheel isn't needed. And if by some chance you can't get the pads out or back in, all you do is take the axle nut loose and push the axle in far enough to free the caliper. The front is even easier. Just remove pins , remove pads and put the new pads in. Clean with brake cleaner and pump the brakes till firm.
Old 05-23-2012, 08:52 PM
Crash75's Avatar
Crash75
Crash75 is offline
very easy....don't pay the stealer for that
Old 05-23-2012, 09:07 PM
Redbeard719's Avatar
Redbeard719
Redbeard719 is offline
Received 1,220 Likes on 545 Posts
Originally Posted by springer 03
Do you have a service manual? That would be the place to start and @$50 it is a worthwhile investment. After looking at it, you can then gauge whether you can do it yourself. The rear caliper on a stock softail involves removing the rear wheel and after that it is very straightforward.
Agree.
And nice choice in bikes there, springer 03!
Old 05-23-2012, 09:14 PM
millzog's Avatar
millzog
millzog is offline
Big Kahuna HDF Member
I concur , takes a few minutes to get all the tools together and then it`s a piece of cake . If you buy the HD pad`s they come with the info on how to change them out . Why pay the stealer ... their already making alot of money .
Old 05-23-2012, 11:16 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
If you are able to change your own oil then you will not have a problem doing the pads. If you can't figure out how to put the transmission drain plug back in then you might have trouble.
Old 05-23-2012, 11:20 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,834 Likes on 17,453 Posts
Take a good look at them I suspect you can handle it just fine , PM me if decide to tackle it and I'll shoot you my cell # for guidance if you need it but it's very straight forward .
2011Deluxe's Avatar
2011Deluxe
2011Deluxe is offline
I didn't have to remove my wheel
Old 05-23-2012, 11:39 PM
WhiteNoise's Avatar
WhiteNoise
WhiteNoise is offline
Too easy.
Quick Reply: How Hard To Replace Rear Brake Shoes On A Softail?
