How much primary oil?
Old 05-20-2012, 10:46 PM
tom lipke's Avatar
tom lipke
tom lipke is offline
Default How much primary oil?
I have an 01 electra glide. what is the correct amount of primary oil? I have heard that the manual calls for 32oz. I have also read that people put in 38oz but I believe that is for the newer models 07 & up. just want to make sure.
thanks
Old 05-20-2012, 10:54 PM
baust55's Avatar
baust55
baust55 is offline
i sugest you buy the correct service manual for your year bike. it will save you tons of dough.
first thing i bought for all of my harleys.
here i found you one on Amazon
http://www.amazon.com/gp/offer-listi...buying-options
Old 05-20-2012, 11:05 PM
NAILIT RK's Avatar
NAILIT RK
NAILIT RK is offline
My service manual 01 RK, states the capacity at 32 oz. however it also states "these are estimates and the level should be check according to the methods in chapter.." (yada yada yada...)
Old 05-20-2012, 11:11 PM
DresserDude's Avatar
DresserDude
DresserDude is offline
32oz sounds correct if I remember.
Old 05-20-2012, 11:16 PM
Honey-Badger's Avatar
Honey-Badger
Honey-Badger is offline
I think, a quart.
Do a google search.
Buying a manual wouldn't hurt.
Old 05-20-2012, 11:42 PM
Fishrrman's Avatar
Fishrrman
Fishrrman is offline
From the service manual for the 2000 FLT models (same primary as on the 01's):
"With the vehicle standing upright, the level of the lubricant must be at the bottom edge of the diaphragm spring or 2 3/4 inches from the centerline of the clutch adjuster screw. The primary chaincase capacity is 32 ounces."
When I do my primary, for lack of something better, I put an ordinary brick under the jiffy stand. This gets the bike "close to vertical", but still a few degrees toward the left side. It won't tip over without an effort, but be careful anyway.
For some reason, 32 ounces may not actually bring the fluid up to the bottom edge of the spring. If that's the case, add a little at a time until it does, and try to keep track as to how many ounces "over 32" you've put in. Then, next time, just measure out this amount and pour it in. Works for me.
Former USMC (05-04-2020)
Old 05-21-2012, 06:08 AM
grbrown's Avatar
grbrown
grbrown is offline
I have a display stand, which makes that check very easy! Fishrrman gives the correct level. If the chaincase is bone dry, say after a primary rebuild, it may well take 32 ounces, but when doing a normal service oil change it will probably take less.
You should never fill any oil reservoir with the stated quantity - always check for the correct level.
Old 05-21-2012, 06:13 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
The important thing is that the diaphragm springs are "just" covered down at the bottom of the clutch pack... with the bike vertical. If you over-fill it based on ounces recommendations alone, or take shortcuts by not getting the bike vertical, then it might make neutral hard to find. So go visual if you are simply changing the primary case lubricant.
If you are rebuilding, then most likely it will take the 32 ounces once all of the oil is distributed to all of the surface areas within the clutch assembly, chain, and compensator parts.
Old 05-21-2012, 07:13 AM
skratch's Avatar
skratch
skratch is online now
Received 4,191 Likes on 2,457 Posts
notice a common theme here?
but, you don't even need a service manual for this. this information is pretty clearly spelled out in your owners manual. and if you don't have an owners manual, you can register online at h-d.com and look it up online.
(but having a service manual is a very handy thing to have)
Old 05-21-2012, 08:40 AM
JEDHRMC's Avatar
JEDHRMC
JEDHRMC is offline
My 03 RG was 32oz, the 2011 is 38oz
Quick Reply: How much primary oil?
