Tour pack lights found on EBAY?
Old 05-18-2012, 05:02 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
got my light and tryed to install it and the sides on the wrap are smaller for one thing won't fit my 07 so back it gos
Old 05-19-2012, 05:19 PM
wolf1956's Avatar
wolf1956
wolf1956 is offline
OK, I finished installing the LED Tour pack light that I got off of Ebay. I went with the chrome version. I wasn't sure just what I was going to be getting when I ordered the light and all I got was just the light. There were no instructions or any type of mounting hardware. However, it wasn't hard to figure out how it mounted. Since I have a 2012 Road Glide Ultra, there were already a couple of mounting holes where my factory antennas were mounted to use a guide. Then it was just a matter of using masking tape to protect the paint and making sure that I had my measurements right before drilling the rest of the mounting holes. I had to drill five 1/4 holes for the extra mounting studs in the light kit. I then used some 1" fender washers with 3/16 holes along with nylon locking nuts (size 10 by 24 thread pitch). The outside lights are suppose to be wired as brake lights, but for now I have them wired as running lights and the center light is wired as run & brake light. Looking at the picture you will see that the outside lights are a little brighter than the center light, but they are all the same brightness when the brake are applied.
It also didn't come with any type of hardware for mounting the factory antennas to the light. The factory antenna stud from my RGU were to long for the light kit. I decided that instead of mounting the antennas on the tour pack I would try the hidden AM/FM and CB antennas from J&M CORP that mount under the fairing.
Overall, with the price for this light being about a third of what the HD light kit cost, I'm well pleased with how it came out.
Old 05-19-2012, 07:38 PM
1st 96 ultra
so your trunk had no lights in it from the factory , they would not work on my 07 ultra and checked with my dealer today and he said the tour pack lights have the same part # from back in like 95
Old 05-19-2012, 07:44 PM
wolf1956's Avatar
wolf1956
wolf1956 is offline
That's correct, the only lights they put on the Road Glide Ultra are the lower side marker lights.
Old 05-20-2012, 05:27 PM
1st 96 ultra
so then that is what they are for is like the classic and such with no factory lights in the tour pack so you can cut your tour pack to fit , they are not replacement lights , was really disapointed because they are nice lights
Old 05-20-2012, 08:08 PM
Mntsnow's Avatar
Mntsnow
Mntsnow is offline
This light is the same basic setup that the 2010 CVO ultra's came with which was kit # 67914-10
As for the antenna studs you can get the required shorter one's from the dealer or just shorten up the long ones with a dremel cut-off tool.
Old 05-20-2012, 08:46 PM
AbnMP13's Avatar
AbnMP13
AbnMP13 is offline
Looks nice Wolf.
Old 05-20-2012, 09:05 PM
Mntsnow's Avatar
Mntsnow
Mntsnow is offline
The Ebay kit is a great cost effective setup for those who want to put a light kit on their chopped tourpaks as the cvo style setup is the one that will fit the chopped paks.
Old 05-20-2012, 10:22 PM
hd_rolling's Avatar
hd_rolling
hd_rolling is offline
Added the same kit just black trim not chrome. If you reverse your positive /negative wire on the corners your lights will be dimmer to match your center light when its just running. I had the same issue and tried changing and it worked perfect. I had to cut the ends they had and just twist tied mine. I also added some LED side markers to get rid of the chrome inserts. Because I have the street glide I just connected my rear lights to the side marker lights and the extra wire to make the middle light a brake light I ran the wire down and connected it seperatly to the harness under the left side cover near the fuse block. These lights a plenty bright and I installed both in about an hour.
I also have the adapters coming to make my side lights run/turn signals and the tail light to be run/turn/bake from ride time tech for all thrre not just the center.
Old 05-25-2012, 12:32 PM
RPS1981's Avatar
RPS1981
RPS1981 is offline
Would one of you guys help me out a little... I'd like to install these on my bike (Classic Tour-Pak on a Street Glide) but I'm wondering where do you connect the wires on the bike? Is there a place they plug in (i.e., unused harness that only gets used on Ultras) or do you have to splice in or connect to the acc. plug or ???
Quick Reply: Tour pack lights found on EBAY?
