Tranny oil change and engine oil
Old 05-06-2012, 06:58 AM
spidermonkey522's Avatar
spidermonkey522
spidermonkey522 is offline
Stage II
Default Tranny oil change and engine oil
I just bought a 2005 883 with 5700miles, what kind of tranny fluid does this call for or better yet what can i use, getting mixed messages in my research. Also in changing the main engine oil a drain location for this year would be helpful, thanks...
No manual
Old 05-06-2012, 07:34 AM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
No manual > No good. This should be your first investment, will save you lots of headaches and money.
I'm using Amsoil in engine and primary.
Old 05-06-2012, 07:40 AM
NAILIT RK's Avatar
NAILIT RK
NAILIT RK is offline
In my TC 88 I run Mobile 1 gear lube in the trans 75-90 weight. Mobile 1 V-Twin in the crankcase,/engine
Old 05-06-2012, 07:44 AM
spidermonkey522
Stage II
I keep running across info saying an 883 does not take tranny fluid but 20/50 instead, just want to be sure
Old 05-06-2012, 07:59 AM
Von_Zipper's Avatar
Von_Zipper
It will take any, just be warned Mobile 1 tranny oil will kill your generator.
Old 05-06-2012, 08:08 AM
CanuckSporty's Avatar
CanuckSporty
CanuckSporty is offline
Put in either 20/50, same as the engine, or Harley Formula+. Your choice.
Old 05-06-2012, 08:29 AM
TheGarbon's Avatar
TheGarbon
TheGarbon is offline
Yech.. Posted to the wrong thread.. Odd...
Old 05-06-2012, 08:38 AM
baka1969's Avatar
baka1969
baka1969 is offline
You need to order a service manual. It will save many headaches.
I use the HD branded fluids for both the engine oil and tranny. I'm going to change it again in another 1500 miles and then will change to synth for all the fluids.
IronBoy883's Avatar
IronBoy883
IronBoy883 is offline
It may cost a little more but when it comes to service I just get all the stuff from Hd and do it myself ...
Old 05-06-2012, 02:33 PM
fox4's Avatar
fox4
fox4 is offline
As it has been said earlier do not use gear oil in the primary/transmission on a Sportster. It will strip the varnish off the stator (alternator for our bikes) and then you will have a lot of work ahead of you.
The HD Formula+ is pretty much the only oil that is specifically made for the Sportster shared primary and transmission. It is the only thing I will use there. I run Mobile 1 V-twin 20w50 in the engine.
Quick Reply: Tranny oil change and engine oil
