S&S B carb adjustments
Old 05-05-2012, 06:50 PM
Hey Zeus's Avatar
Hey Zeus
Hey Zeus is offline
Default S&S B carb adjustments
I have a 1983 FLHT, fresh top ended at basic stock specs, only difference is an upgraded cam from stock to mild Andrews J grind. It runs good however it seems to be running way rich. I have tweaked and tweaked but have yet to really hit the sweet spot. I should have prefaced I am not a carb guy at all, just basic knowledge so I was actually hoping that maybe one of y'all may have a late model shovel with this B series carb and have some advice for me as far as adjustments, etc.
I do use a higher octane gas, no additives or garbage like that......bike is basically stock setup with the small street cam and the B carb. I don't figure it to be too difficult, but to a guy like me it isn't my strong suit......I'm a painter, not a tech
Thanks in advance
Old 05-05-2012, 11:18 PM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,210 Likes on 1,480 Posts
Old 05-06-2012, 05:01 AM
biginchhustler's Avatar
biginchhustler
biginchhustler is offline
depends on altitude-- sea level 80" 70 main jet -- high altitude 68 main jet
biginchhustler
best spark plugs AUTOLITE XS 65 do not try to gap them --
Old 05-06-2012, 05:04 AM
biginchhustler
late 80 heads had the .625 guides and cam selection was limited to small lift cams.. if you can find a sifton 412 its a .390 lift bolt in and wayyyyy better than that "J"
Old 05-06-2012, 05:08 AM
biginchhustler
also the "B" or even the "E" carb when you first start the bike you need to turn the A/F screw out an extra 1/2 a turn till it warms up... i attached a piece of 1/4" hose to my screw so i can do just that.. its a carb not FI.. the A/F screw should be 1 1/2 to 1 3/4 turns out to start till you find the "sweet spot" best tuning of this is done when it fully warmed up..
Old 05-06-2012, 01:23 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,834 Likes on 17,453 Posts
How old is the "B" ? those had a tendency to wear throttle shafts and leak air around the butterfly making them a bit of bear to fine tune and have them stay there . Also the the bowl breather port on the left side as you look at them would gunk up a bit which made it act like the float was off sometimes . The intermediate jet in those mean more that the main for 80% of your normal riding should be .031 and again this depends on where you live higher altitude will drop it to a .0295 .
Mr1986FLST
EVO
34
09-26-2021 05:13 PM
02maddness
EVO
03-31-2012 10:15 AM
Glider rider
EVO
08-17-2011 02:45 PM
stoneman
05-15-2011 07:51 PM
ukchop
04-01-2007 11:01 AM
Quick Reply: S&S B carb adjustments
