Fatboy seat removal
Old 01-03-2007, 12:27 PM
East Texas Fatboy's Avatar
East Texas Fatboy
East Texas Fatboy is offline
Default Fatboy seat removal
Going to hookup battery tender on my bike but after loosening all 3 seat screws, unable to remove seat.I know to pull rearward but just how hard? Have learned with many years experience that's it's best not to force things. Tends to get expensive when you dont ask or read instructions. Any help is appreciated.
Old 01-03-2007, 12:39 PM
Tin Gizel's Avatar
Tin Gizel
Tin Gizel is offline
Default RE: Fatboy seat removal
I know on mine, i have to pry one of the sides loose before the seat will move. There's a little lip that the side screws sit on.....just unscrewing them won't let me remove my seat. Got kinda frustrating the first time.
Old 01-03-2007, 12:45 PM
dugan's Avatar
dugan
dugan is offline
Hmmm, don't have any problem removing mine from my 07 FB. After removing the pillion, and if I recall the strap is bolted down, then remove the two large bolts that attach to the lip of the main seat and then it should slid back and off.
Old 01-03-2007, 12:54 PM
anubisss's Avatar
anubisss
anubisss is offline
I got mine used with a single screw on the rear fender holding the seat on. thank god...Simplicity...
Old 01-03-2007, 01:52 PM
fatboy4ever's Avatar
fatboy4ever
fatboy4ever is offline
First time for anything is a little difficult . Make sure that you have the passenger seat off and also the "grab strap". The grab strap can sometimes get in the way. Lossen the screws all the way (so you can't feel them grab anything). I would then put a towel down over the back fender and "drape it" over the sides of the bike. Wiggle the seatback and forth and pull away from the tank. It should come out fairly easily.
Good Luck!
Old 01-03-2007, 05:56 PM
Cobeslayer's Avatar
Cobeslayer
Cobeslayer is offline
My experience was the same as TinG's. Eventhough backed out all the way, the side screws were the culprit. GENTLY pry one of the sides and you should be good to go.
Old 01-03-2007, 06:00 PM
Fatbernie's Avatar
Fatbernie
Fatbernie is offline
ORIGINAL: Cobeslayer
Yup. I agree here. Giggle the sides after you have the two screws completely loose and my grab strap has a snap in the middle that has to be undone in order to get the seat to fit through it. Don't forget to snap it back up when putting the seat back on.
BA
Old 01-04-2007, 12:35 AM
wildman67's Avatar
wildman67
wildman67 is offline
remove back screw, loosen 2 side screws and pull back!
kpd
General Topics/Tech Tips
01-01-2015 08:33 PM
MorrisGray
09-14-2013 09:55 PM
LuvtheMud
09-16-2007 02:52 PM
fxdwgcvo
03-05-2007 12:18 PM
sonar_chris
08-20-2006 05:21 PM
Quick Reply: Fatboy seat removal
