120R Questions
Old 05-02-2012, 11:31 PM
D Mo's Avatar
D Mo
D Mo is offline
Default 120R Questions
So, I've been following a couple threads on here and have been inspried to replace my 103 with a 120R.
I went to my local dealer today and asked some questions of the mechanic. Not sure I really liked what he had to say. I asked him if he could do the tuning and he said yes and he had done one recently. I asked him what kind of HP he got out of it. He said 103HP. He did say the owner had stock exhaust and a stock air cleaner.
He did mention the D&D Boarzilla exhaust, which is what I am considering. I asked about the SE Heavy Breather and he said it was no good. Odd, since it appears that most of the 120R setups with big numbers (125+) are running that part. Or at least that's what it looks like to me.
He did say that HD is working on a replacement TB, and they have one on order for another customer. If that doesn't work, HPI has a slick set-up that would work with injectors to match. I was ok with that part.
When I questioned the 103HP number, he told me that was about right, maybe a little more and that the 125HP that I was expecting would be a stretch and require a lot of work.
Does any of this make sense to anyone else? I'm about to spend $6k+ on the 120R and everything I need and this guy is shooting down my dream.
Please help before I abandon ship on this project.
Thanks,
Old 05-03-2012, 12:15 AM
nytryder's Avatar
nytryder
nytryder is offline
Think I'd try another wrench.
Old 05-03-2012, 12:27 AM
dbell66253's Avatar
dbell66253
dbell66253 is offline
My local dealer tried to convince me to get the 120, one of the things he guaranteed was at least 120hp at the rear wheel, on any dyno, I think if I were you I would find somebody who wants to do the job, and with some enthusiasm.
Old 05-03-2012, 07:29 AM
partycrasher's Avatar
partycrasher
partycrasher is offline
find a new mechanic.....that guy has no idea what he;s talking about.
Old 05-03-2012, 10:44 AM
grbrown's Avatar
grbrown
grbrown is offline
Just because he's not telling you what you wanted to hear doesn't mean he doesn't know what he's talking about! You haven't learned enough yet, so take a little more time reading through the 120R threads here and sift through the info available. Quite a few of the big numbers are coming from modified 120Rs, whose owners couldn't leave them alone! By picking your way through those threads you can find a build that used a stock motor and got sensible numbers, to base your own build on. Then you can talk to your mech again.
Old 05-03-2012, 12:19 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
Maybe I'm wrong, but if the 107 kits are turning numbers low 100s to 110 HP, shouldn't a 120R be doing a lot better then that?
Old 05-03-2012, 12:27 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
Did he happen to mention the fact that the 120R has no warranty? That's why it has the "R" suffix, race=no warranty. It would be real hard for me to drop 6 large on a motor with no warranty.
Old 05-03-2012, 12:37 PM
garyFLHPI's Avatar
garyFLHPI
garyFLHPI is offline
I would stick with your original mechanic. He knows what he is taking about.
Old 05-03-2012, 01:15 PM
XARAN's Avatar
XARAN
XARAN is offline
I'd seriously look at a good 107 kit, it can be done for about 1/3 the cost and IMO the Hp/Tq in the end isnt that much different than most of the 120r unless they are putting a lot more into them.It isnt worth an extra $ 3000.00 +
Jamie is making 106/118 and 107/120 with his 107 kits, the basic kit is $1300 installed and dynoed by them $ 1900.00 with R/T shipping of $ 800.00 you could send your bike to them and for the install and still save $ 3000.00.
http://www.fuelmotousa.com/107kit.htm
And Im sure there are others out there doing the same kind of numbers, look for some good engine builders in your area.
Old 05-03-2012, 01:26 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
+1, this is the route I would take. The 120R is way too new and too many unknowns.
Quick Reply: 120R Questions
