Sponsored by: Jekill and Hyde
Engine case serial number problems
Old 04-30-2012, 06:00 PM
mrsmartass2003's Avatar
mrsmartass2003
mrsmartass2003 is offline
2nd Gear
Default Engine case serial number problems
Just bought an 02 special construction softail. It was originally built by cycle connection in Joplin,MO wich is a Harley dealer. All the owners of the bike claim to have not changed anything and the dealer is claiming the motor is a 80ci revtech engine. First of revtech said they never made a 80ci and the serial isn't one of theirs. I've called all the major motor and case manufacturers with no luck. Maybe someone on here can help me. The numbers on the case are located just below the jugs in the middle of them. Number has the open star at the end and beginning of the number. The number is BKLT******. Thanks.
Old 05-15-2012, 04:38 PM
mxsurdo's Avatar
mxsurdo
mxsurdo is offline
Stage II
Good luck, Bro. I've also got a serial # problem. A friend found an HD 45 motor in a barn. The only serial # is T21456 located on the case between the jugs on the left side. It has a large pulley (maybe 20" dia.) attached to the crank. I need to know where this motor came from. Thanks.
Old 05-16-2012, 05:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
In regards to the 45"er, here in NYS, you can get those registered, by taking those numbers to the DMV, with a pencil tracing, and if it has not been registered in quite some time, they'll issue you a registation.
That 20" pulley on that engine indicates it may have been used for an irrigation pump, sawmill, or for some other remote power source.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 05-17-2012, 06:58 AM
mxsurdo's Avatar
mxsurdo
mxsurdo is offline
Stage II
Thanks for the info. I suspected that the 45 was used as a power source. I'm still trying to figure out what the serial # indicates.
aaronbacon
09-07-2015 04:50 AM
phil45
Flathead
08-03-2014 12:07 PM
lchaim7
03-09-2014 12:27 AM
Gmiller1959
08-15-2012 11:18 AM
davepapa
07-14-2012 02:48 PM
Quick Reply: Engine case serial number problems
