$4 Sportster Rear Turn Signal Relocation Kit
Old 04-26-2012, 03:02 PM
buell12's Avatar
buell12
buell12 is offline
Arrow $4 Sportster Rear Turn Signal Relocation Kit
I have seen many home-made blinker relocation setups, but this design is by far the simplest (both to build and elegant design) and can be adapted to just about any style of bike (chromed, blacked out, or whatever) - just change the rod covering material. I did this on my Dyna and donated a couple bucks to the guy's website. Just thought I would pass it on.
In my opinion, simple is best....
http://www.v8v2.com/index.php/wheels...r-fxdp/how-tos
Old 04-26-2012, 05:43 PM
Trainwrcked's Avatar
Trainwrcked
Trainwrcked is offline
Nice. The only thing I would change would be to try and hide the wires to the lights. I'm wicked OCD about wiring showing.
Old 04-26-2012, 05:56 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
I relocated my signals to the trash can. Cost me nothin.
Old 04-26-2012, 06:07 PM
Trainwrcked
That's one way to do it...
Old 04-26-2012, 08:28 PM
simmy711's Avatar
simmy711
simmy711 is offline
What SF said... LOL!
Old 04-27-2012, 02:36 PM
jerryw618's Avatar
jerryw618
jerryw618 is offline
I got two 2 inch bolts 4 black nylon washers 2 chrome spacers from Ace hardware and made these signal mounts for my bike , they work great and are spaced just right for my saddlebags , only cost me $4.00 and change , a couple of bolts and washers and spacer it doesnt get much simpiler than that .
Old 04-27-2012, 03:06 PM
PasadenaNightster's Avatar
PasadenaNightster
PasadenaNightster is offline
Looks Good Jerry! how is the turn signal mounted? Is it a threaded rod? Or did you run the bolt from the inside out?
Old 04-27-2012, 04:30 PM
jerryw618's Avatar
jerryw618
hello there thanks for the reply. i just ran the bolts from inside the fender out did a dab of loctite on the threads put on the washer spacer washer then the light, snugged it down , i ran the wires thru the fender holes after putting in rubber grommets there to keep the wires from rubbing the metal edges, ran wires along inner wall of fender there are clips there for the wires and hooked the wires up in the taillight assembly as they normally go . nice clean look and they havent moved in like two years.
thanks again ride safe , ride often
Old 04-27-2012, 05:40 PM
chad883's Avatar
chad883
chad883 is offline
Haha TOUCHE SF! I'm right there with you
Old 04-27-2012, 07:12 PM
streetfighter06
Looks rad. Nice job!
Quick Reply: $4 Sportster Rear Turn Signal Relocation Kit
