Cost To Powder-Coat the Engine/Trans??
Old 04-24-2012, 03:17 PM
rocknrod's Avatar
rocknrod
rocknrod is offline
Default Cost To Powder-Coat the Engine/Trans??
I'm wondering what you guys thought it would cost to have my heads, jugs, crank case and tranny powder-coated?
I mean if I went to someplace and dropped it off. I don't have the special tools to remove and replace everything needed.
Old 04-24-2012, 03:52 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Youd be 15-17 hours labor, couple hundred in gaskets and bearings plus the powder coating. Make sure the powder coater can do heads and cylinders to stand up to the heat. Seen someturn funny colors neer the hot spots.
Old 04-24-2012, 04:48 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
You want to save this until the motor needs rebuilding.
No sense in taking it apart just for color.
And you have to be sure the guy putting your motor back together knows what he is doing
Mike
Old 04-24-2012, 09:25 PM
rocknrod's Avatar
rocknrod
rocknrod is offline
I would hope so too.
So anyone know how much money this might cost?
Old 04-24-2012, 09:36 PM
fishn4life's Avatar
fishn4life
fishn4life is offline
I didn't do the heads but just finished with about 100 pieces total and spent around $750 for the PC.
If your not short on time or patience buy a manual and disassemble yourself, you'll save a lot in labor.
If you don't want any headaches and have the money then figure around 3K gaskets, labor, & PC)
Also, do some homework on your powder coater.
Old 04-24-2012, 09:37 PM
fishn4life's Avatar
fishn4life
DP...
Old 04-25-2012, 01:11 PM
06redneck's Avatar
06redneck
06redneck is offline
i am doing same thing right now to my motor. i called precision powder coating in spring tx and they said $100 for powder coating cases, $60 for cylinders, and $120 for heads. I hear they are pretty good and offer 2 year warranty on their work. i have heard horror stories about powder coating chipping off the engine after it came back from a powder coater. make sure you get someone that is reliable
Old 04-25-2012, 01:55 PM
son of the hounds's Avatar
son of the hounds
son of the hounds is online now
Received 2,515 Likes on 1,302 Posts
I just had the heads and cylinders done. $ 200.00. They were in good shape to start with. Time you pay for is prep, masking, etc.
I have a frame, swing arm, brackets, guards, levers, bolts, totalling 27 pieces, etc in at a powder coater now. I will expect to pay another $ 250.00 or more. I did not do covers. I would expect it would add at least $ 100-150 more.
I degrease everything before taking the parts over. They mask, sand blast, acid etch, powder coat, bake etc.
Old 04-25-2012, 05:03 PM
rocknrod's Avatar
rocknrod
rocknrod is offline
I have a manual. I dont have the special tools.
The cost of the powder coating is okay.
It's the tear down and re-assembly that I'm worried about.
Old 04-26-2012, 12:40 PM
Bobber Jake's Avatar
Bobber Jake
Bobber Jake is offline
Get a couple of cans of BBQ grill paint, mask it off and paint it.....and then you can always touch it up when you need to.
lkr0 (06-20-2017)
Quick Reply: Cost To Powder-Coat the Engine/Trans??
