se 254e cams
Old 04-21-2012, 02:56 PM
NMNSG08's Avatar
NMNSG08
NMNSG08 is offline
Default se 254e cams
I'm going to try these cams in my 08 sg.The motor is stock with se heavy breather and se mufflers(old style with no cat in them).I'm not looking for big numbers just a little more from the little 96"er.Hopefully they will do the job.Also doing the 30t tranny pulley and the 68t rear pulley.
Old 04-21-2012, 03:08 PM
ColoSpgsMark's Avatar
ColoSpgsMark
ColoSpgsMark is offline
You should like them. Well mannered and smooth. Starts to come on after 2500 rpm, but that is where I want it and better than stock all around. Easy to tune also - make sure you do.
Old 04-21-2012, 03:12 PM
NMNSG08's Avatar
NMNSG08
NMNSG08 is offline
I am going to tune,i'm using a sert to do it since i already have it.
Old 04-21-2012, 04:00 PM
Bruce00's Avatar
Bruce00
Bruce00 is offline
best of luck to you
just wondering why you have decided on the 254's?
do you run your motor aboue 5K often, not trying to change you mind, just curious
I was in your shoes not long ago, and looked at those cams too, but went with a different cam choice for earlier tq
Old 04-21-2012, 04:17 PM
NMNSG08's Avatar
NMNSG08
NMNSG08 is offline
I decieded on these cams due to the gear change and stock compression of the motor.also i like the tourque of them.
Old 04-21-2012, 06:27 PM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
You are going to love the 254e cams more take off power,
and more 18 wheeller passing power. If I was you I'd do
the cams first, then decide on wheather to change out the
gears or not, you might not have to.
Old 04-21-2012, 06:39 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is online now
im a fan of gearing i would change that firist so i could compare the difference,either way do it one at a time,you'll be surprised what just gearing can do.
Colin1966
11-10-2012 08:41 PM
NMNSG08
04-25-2010 07:33 PM
JCK
08-05-2009 08:09 AM
txtec
Dyna Parts
07-19-2009 11:11 PM
StreetglideOK
Exhaust System Topics
11-11-2007 07:36 PM
Quick Reply: se 254e cams
