Powder Coating Exhaust? Can it be done?
Old 04-19-2012, 07:50 AM
NightTrainBM's Avatar
NightTrainBM
NightTrainBM is offline
Default Powder Coating Exhaust? Can it be done?
I have chrome pipes now.. Can they be powder coated? Or do they have to be ceramic coated to withstand the heat?
Old 04-19-2012, 07:59 AM
hspring03's Avatar
hspring03
hspring03 is offline
I had mine sandblasted and then sprayed them with High temp BBQ Krylon.
4 years and I haven't had to touch them up. Nice cheap solution.
You can have them professionally ceramic coated to with stand the heat
Old 04-19-2012, 08:01 AM
hdgzr's Avatar
hdgzr
hdgzr is online now
Received 1,869 Likes on 595 Posts
My local PC shop says it can be done. They have a coating that holds up to 1200 degrees F...
Old 04-19-2012, 08:20 AM
jetmech74's Avatar
jetmech74
jetmech74 is offline
if you're talking about the heat shields, yes, directly on the pipes no
Old 04-19-2012, 08:49 AM
NightTrainBM
Jet mech - yea. The heat shields only.. Not the actual pipes. Might be a winter project.
I like the BBQ paint idea. But if I'm
Going thru the trouble of having someone sand blast them, I might as well just he the PCed.
Old 04-19-2012, 09:21 AM
kaynine840's Avatar
kaynine840
kaynine840 is offline
regular powder coat-NO. you'll have to do something that can withstand the heat thermal ceramic or like others said, the high temp BBQ paint. i got mine thermal coated black and it has held up 100% for 4 years now. no discoloring, or flaking, and holds up against scratches too
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Both my pipes and shields are ceramic coated. Even the inside of the pipes are ceramic coated.
Old 04-19-2012, 09:26 AM
NightTrainBM
Kaynine - approx what was the cost??
Old 04-19-2012, 09:38 AM
kaynine840's Avatar
kaynine840
i had them sent out to cradin industries and they charged around $200, i believe. they do great work. they'll also do pipe tattooing too, if you've ever heard of that. another good place is jet hot, but they are really expensive.
Old 04-19-2012, 09:48 AM
x1rider's Avatar
x1rider
x1rider is offline
Another alternative would be Techline Coating's Black Satin (you have to apply it with a touch up paint spray gun).
I did my car's turbo hot side, exhaust manifold, and downpipe with it. It is holding on really well and whitstands very high temperatures.
They say that the curing is done while the pipe is heated up from running the engine but I didn't take any chances and cured mine in my home made oven that I had built for powdercoating.
Quick Reply: Powder Coating Exhaust? Can it be done?
