what went wrong?2010 wide glide
Old 04-16-2012, 10:35 PM
RAN WOODMAN's Avatar
RAN WOODMAN
RAN WOODMAN is offline
Default what went wrong?2010 wide glide
put on new 14 inch wild one apes and used novello wire extensions.now got no headlights or signals and wont even turn over.holy crap.can anybody please give me some badly needed advice at what to do next?
Old 04-17-2012, 01:11 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Loose the extensions and solder on connections so they dont pull apart as you drag the wires through the bars!
Old 04-17-2012, 05:30 AM
RAN WOODMAN
Unhappy what went wrong
thanks for reply but have extensions already soldered together.plus they are outside the bars and checked contiunity back to original wiring down to end of pins on new extensions and every thing is fine but still no headlights,signal lights,no fuel pump cutting in and wont even turn over.only brake lights ,dash lights and all signal lights are on but wont flash.what a frustrating mess.
Old 04-17-2012, 08:10 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
Then you must have wires in the wrong places in the connectors
Old 04-17-2012, 03:18 PM
RAN WOODMAN
took pins out of connector and put them directly into other connector and every thing worked.seems that the pins werent pushed in far enough in connector to make contact as they were bent a little and were not going right through the tiny holes.Had to bend every one of them to go in place.what a relief when it all worked.Took bike out for run and i noticed my gas hand not working which is not to serious but will have to have a look at it another day.anyway tanks for taking the time to reply.It is very much appreciated.
Fscott4
02-26-2018 11:11 AM
rydahog
Electrical/Lighting/Alarm
07-02-2017 07:39 PM
wideglide2015
11-07-2015 05:04 PM
pheur
08-15-2012 02:30 PM
JDixon
01-29-2008 11:27 PM
Quick Reply: what went wrong?2010 wide glide
