error code P1510, P2122, P2138
Old 04-09-2012, 09:45 AM
jomohog's Avatar
jomohog
jomohog is offline
Stage III
Default error code P1510, P2122, P2138
I ride a 2008 Ultra, I changed the Throttle by wire and it was bad, figured that would fix problem but it hasn't still getting codes. I spoke to a tech at my local HD shop and he said check the wiring on left side along the neck that sometimes a wire gets smashed by forks and will break a wire so it doesnt always make contact anyone else fighting this problem, if so could you give me a lil elp where to start.
Old 04-09-2012, 11:20 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
Try unplugging the throttle body and gently cleaning both sides of the connectors and applying dielectric grease on both sides before re assembly. This is where my 08 was giving me trouble about 2 years ago. There is a tech bulletin that any HD tech worth his salt should be aware of, it is HD TT418 ,concerning this issue.
Old 04-20-2014, 05:09 AM
Potovyreplo's Avatar
Potovyreplo
Potovyreplo is offline
5th Gear
thanks for the info guys. it'll really help me.
Old 04-20-2014, 07:36 AM
crimson13's Avatar
crimson13
crimson13 is offline
Also you can check the connections , if there is not a good contact it will also cause these codes.
One of my wires had a bad crimp at one of the pins
Sent from my iPhone using IB AutoGroup
fordhd2005
06-17-2022 11:22 AM
MegaJohn
02-12-2022 03:59 PM
TriGeezer
10-24-2014 10:32 PM
BRW
Electrical/Lighting/Alarm
06-25-2011 11:26 AM
rmwill
07-08-2006 04:18 PM
Quick Reply: error code P1510, P2122, P2138
