Help with crazy air valve in handle bars!!!
Old 04-08-2012, 06:19 PM
Deebz's Avatar
Deebz
Deebz is offline
Default Help with crazy air valve in handle bars!!!
So I went change my bars today and discovered the air valve in the end of my bars....connects to a hose inside the bars which comes out of the bars up under the gauge cluster and into some metal hoses that are bolted to the top of the forks...is this air for the forks and how the hell do I swao the bars with this set up???
Thanks
Old 04-08-2012, 07:08 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
I believe that is for a bike with front air ride forks right? I would guess that the handle bar connection is just an end for the air purge system. Again this is conjecture and I am not 100%
Old 04-08-2012, 07:20 PM
dc1450's Avatar
dc1450
dc1450 is offline
The handlebars are the air tank for the forks. You must have an FXRS-SP or Convertible. You can eliminate the handlebar tank but, you will reduce the volume of air in the suspension system. It probably won't be to big a deal but, the bike may ride a little stiffer.
You can add separate schrader valves to each fork leg or mount one in the hose and move it to a place where it's convenient.
You can also eliminate the air altogether with standard fork caps and just have regular forks.
Old 04-08-2012, 08:46 PM
Mountainkowboy's Avatar
Mountainkowboy
Mountainkowboy is offline
You could also add a small air tank and just go with regular bars.
Old 04-08-2012, 09:39 PM
Deebz's Avatar
Deebz
Deebz is offline
I got er figured out guys, thanks. Just gonna eliminate the air.
Old 04-10-2012, 08:13 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
If your anti-dive worked before, you may be disappointed going to regular forks. Went that way for a while, didn't like it, too much front end dive. Had a bud at work fab up a flask type reservoir, looks cool and really makes the front end feel much lighter. jmho. 90 fxrs-sp. Most folks ruin the anti-dive by not using a bicycle pump to set the correct pressure, if you're not careful you may blow fork seals. Love mine, don't know what I'm gonna do when I can't get parts anymore. P.S. , using a 1 cup measure the bars only held 3/4 cup I think, not sure, but not much, can be hid anywhere.
Old 04-12-2012, 08:55 PM
caleb895's Avatar
caleb895
caleb895 is offline
Default handle bar air storage alternative
Got any pics of your reservoir? I started putting 14' apes on my 92 FLHTC tonight and I had originally planned on moving a schrader to the bottom of my inner fairing.
I really like the anti-dive effect and the light feel in the front-end and I'd rather it not change any if possible. I've been coming up with some ideas for a reservoir after reading your post but I'd love to see how it was done successfully by someone else before i attempt it.
Old 04-13-2012, 08:16 AM
grbrown's Avatar
grbrown
grbrown is offline
Seems a brief description of what you have is in order! You have air assisted front suspension, with anti-dive. The handlebars are an air reservoir that you can pressurise up to 20psi, to provide adjustment for the stiffness of the forks. When you operate the front brake, you operate a solenoid that shuts off the handlebar reservoir, leaving only the air in the forks. This stiffens the fork action while the brake is applied, reducing fork dive.
The forks also have springs, but they are soft for use on their own. The air system is remarkably effective and mine still works on my 1990 bike. If you junk the air system you would do well to fit stronger springs, to compensate.
Old 04-13-2012, 12:04 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
Graham is right on the money, soft fork springs with no air. Progressive springs may solve all your problems if you go without air assist.
Old 04-14-2012, 07:23 AM
busterman2's Avatar
busterman2
busterman2 is offline
I moved the air valve out of handlebars on my 91 FLT and used no resevior. It works fine, but when I pump up air it takes about two short strokes with air pump compared to several softer full strokes with air pump when valve was in bars. Like I say, air suspension works fine with no resevior, any down side to no resevior.
Best bike school
EVO
06-05-2020 06:12 PM
2-whlz
Air Suspensions
11-07-2014 06:13 AM
Thumpernh
03-03-2012 07:35 AM
2-whlz
11-19-2011 10:13 PM
OCCFAN
07-25-2005 03:23 AM
Quick Reply: Help with crazy air valve in handle bars!!!
