Mallory Distributor
Old 04-02-2012, 04:48 PM
woollyb's Avatar
woollyb
woollyb is offline
Default Mallory Distributor
I am running a Mallory distributor on my 48 pan. Saturday night the cover screws vibrated out and the cover came loose. One of the wires was broken. I fixed the wire but I think the module is also bad now. The bike will fire but it won't run. I was wondering if any of you might know where I can find a replacement module. The part number on the one I have is 6001M.
Thanks,
Woolly
Old 04-02-2012, 06:56 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I have not used the mallory-
but if you need a replacement sensor unit ( 12 and 6 volt) inside the stock points cover:
http://www.ebeyond2000.net/quickstart.html
which I use on my '53.
It is flawless and worth every penny.
Mike
Old 04-02-2012, 08:43 PM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,222 Likes on 1,483 Posts
Here is the address an phone for Mallory....might give them a call
550 MALLORY WAY, CARSON CITY, NEVADA 89701 (702) 882-6600
Old 04-02-2012, 08:50 PM
soft 02's Avatar
soft 02
soft 02 is offline
Thanks,
Woolly
Does it look like this? http://www.jegs.com/i/Mallory/650/61...FQUZQgodzXXn0A
Old 04-02-2012, 09:00 PM
wcjones1010's Avatar
wcjones1010
wcjones1010 is offline
i called them today, the 6001m is just a stock#, i told them i had a e spark 6001m for harley 73 flh, he told me the part # is really 8554 and sent me the diagram for it.
Old 04-02-2012, 09:09 PM
woollyb's Avatar
woollyb
woollyb is offline
I tried mallory but they don't sell direct. They did say autozone should be able to get it for me. Going to try them tomorrow. If not I will give jegs a call. Thanks for the help.
Old 04-02-2012, 09:22 PM
soft 02's Avatar
soft 02
soft 02 is offline
Napa carries Mallory via Balkamp too. http://www.napaprolink.com/results.a...word&Nty=1&N=0
Old 04-04-2012, 06:21 PM
woollyb's Avatar
woollyb
woollyb is offline
I contacted Mallory again. They told me the part number was now A605. I then tried autozone but no luck. I ended up ordering off Mallory's website. $102 total. I hope this takes care of the problem. I tried to start her today and its still doing the same thing. It will fire and thats it.
Old 11-14-2023, 01:06 PM
drtybiker kaos's Avatar
drtybiker kaos
drtybiker kaos is offline
Stage I
How did this play out for you???
Old 11-14-2023, 03:25 PM
woollyb's Avatar
woollyb
woollyb is offline
Worked out great! I still have it on the bike and working fine.
Uncle Larry (11-14-2023)
Quick Reply: Mallory Distributor
