Road King front fender
Old 04-02-2012, 12:05 PM
HazelCreek's Avatar
HazelCreek
HazelCreek is offline
Default Road King front fender
I am replacing a clean front fender on a 2005 Touring Road King (FLHRI) with a stock 2010 lighted tip fender. 1) Do I need to remove the wheel to swap fenders? 2) Does the non-functioning toggle switch to the left of my passing light switch have anything to do with the tip light? Or do I connect the tip light wiring behind the headlight?
In case you can't tell, I am a newbie - a proud Harley owner for two weeks now!
Old 04-02-2012, 03:36 PM
fenderzig's Avatar
fenderzig
fenderzig is offline
Welcome to the forum, Hazel. Congrats on the new bike. I've never taken my fender off so I can't comment on your first question but PLENTY of guys on here have so it won't' be long.
The non-functioning toggle to the left of your passing lamps toggle is your accessories toggle. You can tap into it under your seat and use it for things like heated gear or a power outlet in your bags. It isn't required for your new lighted fender.
Old 04-02-2012, 03:43 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
Tip light is hooked up to work when the other lights are on. In otherwords, all the time. I don't think you'll have to remove the wheel, but it may make it a lot easier to remove and replace the fender with it out of the way. Otherwise you may need an extra set of hands to prevent scratching them during the process.
Old 04-02-2012, 03:44 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
the fender tip light you can probably wire into a grey wire attached to the headlight wiring- that is for the euro- spec position or "city" light and will work fine.
easier to swap fenders with the wheel out of the way- don't want to fumble and scratch it
Mike
Old 04-02-2012, 03:47 PM
HazelCreek's Avatar
HazelCreek
Thank you.
Old 04-03-2012, 04:03 PM
TomWoodgeard's Avatar
TomWoodgeard
TomWoodgeard is offline
If the fender has never been off, there are locking tabs on the mount bolts. The wheel needs to come off so you can take a screwdriver or small chisel and a hammer and tap the locking tabs open. Most people then just use loctite on the bolts when mounting the new fender. Watch out for the thin fiber washers that are between the forks and fender. You MUST reuse these or your paint will chip after awhile.
Old 04-03-2012, 10:00 PM
danmo's Avatar
danmo
danmo is offline
I just swapped my fender last week without taking the wheel. Was a hassle but not terrible to do.
Old 04-04-2012, 01:15 PM
HazelCreek's Avatar
HazelCreek
Thank you for all the info. I will give it a try this weekend when my kid is home to help me.
Old 04-04-2012, 01:49 PM
giobott's Avatar
giobott
giobott is offline
Default 2009 road king
I have had to work on front fender, You get cleaner results if you take wheel off, pretty easy with a stand. I used the accessory switch to run my auxillary fog lamps as the switch can be confingued to be turn off when the ignition is turned to off.
Old 04-04-2012, 02:36 PM
durtyburt's Avatar
durtyburt
durtyburt is offline
There should be a small 2 wire plug behind the headlite to plug fender-tip lite into.
Quick Reply: Road King front fender
