New Mobil 1 Oil Filter?
Old 04-01-2012, 12:01 AM
BlazingC5's Avatar
BlazingC5
BlazingC5 is offline
Default New Mobil 1 Oil Filter?
I'm doing my first oil change this weekend and picked up some Mobil 1 V-Twin synthetic and a chrome Mobil 1 motorcycle filter #M1MC-132.
I did quite a few searches trying to find information on this filter and nothing seems to come up.
Has anyone used this filter or have any information as to whether this is a good filter to use on our Harley engines? Or is this really a new Mobil 1 product?
Old 04-01-2012, 07:07 AM
Cup's Avatar
Cup
Cup is offline
Only Mobil-1 filter I've seen people use is the M1-102. Id check the Mobile-1 site and see what it says about the filter in question.
Old 04-01-2012, 10:00 AM
BlazingC5's Avatar
BlazingC5
The guy looked up the filter and the M1MC-132 was what was referenced for my bike. After I got home, I thought I'd do a search to see if there was any feedback on the usage of this filter. I can't seem to find any thing on it, not even on Mobil 1's site.
I do know that this is a Mobil 1 branded filter specifically for motorcycles, which is what the "MC" designation indicates on the part number.
It is my understanding the the M1 series of filters were actually automotive filters.
Old 04-04-2012, 10:45 PM
gravel_rash's Avatar
gravel_rash
gravel_rash is offline
Stage I
These are new filters now coming on the market for bikes. There is also a non-chrome filter M1MC-131 if you are interested. These new filters are hard to find, but if they are like other Mobil1 Extended Performance oil filters, they should be pretty good.
I know the following site has great deals on m1-xxx and m1c-xxx filters. I contacted them and they said they will be selling the M1MC-xxx filters very soon: www.filtersandwipers.com
Old 04-05-2012, 10:48 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
The most important thing in a HD filter is an ADBV to keep it full of oil when you shut the bike off. The second thing is bypass pressure rating and third is filtration rating. Since HD doesn't publish anything but the 5 micron rating it makes it very difficult to find aftermarket filters that have the same bypass pressure rating. You can simply look in the filter plate holes and see the orange or black Anti Drain Back Valve.
Old 04-05-2012, 10:53 AM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
If it's an automotive filter I wouldn't use it. The twinkies need a specific spec. I think it's 5 microns and a certain bypass pressure. The auto ones may fit but I don't know if they meet the criteria.
Stick with the Harley offering,or the amsoil one. I know the amsoil one meets Harleys spec.
Old 05-20-2012, 06:01 PM
Kmp259's Avatar
Kmp259
Kmp259 is offline
Stage II
The MC M1 132 Chrome Harley oil filter is the same as the Harley oil filter, with the exception that the anti drain back valve is silicone on the M1 and neoprene in the Harley filter.
These filters, Mobil 1 and Harley filter are made by Champion.
Mobil 1 is better because of the silicone anti drain back valve. Will not get hard with heat or age, stays pliable and responds quicker.
New on the market.
Hope this helps.
Old 05-21-2012, 01:26 AM
BlazingC5's Avatar
BlazingC5
Kmp, thank you for that added detail about the new Mobil 1 oil filter.
I've been running that filter with the Mobil 1 V-Twin and the bike seems to be running cooler and sounds great.
Old 06-13-2012, 07:02 AM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
http://www.showmetheparts.com/mobil/
check the motorcycle applications list. It's in there. The mc stands for motorcycle application. Should be as good as the other mobil 1 filters. Yet the only way I have found to be able to get one is to special order thru autozone, advance , or oreilly. No shipping charges deliver to store, usually next day or 2.
Old 06-15-2012, 10:30 PM
BlazingC5's Avatar
BlazingC5
I was able to buy them from Pep Boys. They are on the shelf right next to the Mobil 1 V-Twin Synthetic.
13RoadKing
Engine Mechanical Topics
17
02-18-2017 09:05 AM
P51Driver
11-22-2012 10:43 PM
terrapin88
EVO
13
06-24-2009 12:30 PM
hawk
02-24-2005 12:27 PM
LordVngr
12-28-2004 06:20 PM
Quick Reply: New Mobil 1 Oil Filter?
