sportster hp?
Old 12-25-2006, 04:15 PM
streetbobjim's Avatar
streetbobjim
streetbobjim is offline
Default sportster hp?
I have an 04 883 sportster. I have bought a set of cycle shack baloney cut mufflers, a K&N free flowing filter and a stage 1 jet upgrade kit. Once they are fitted, am I likely to get any increases in power and torque? and if so, Would anyone like to have a rough guess at to how much the increases might be?
Old 12-25-2006, 04:37 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
Default RE: sportster hp?
Hell yeah, you'll get an increase in both horsepower and torque. Approximately 12% - 17% on each. I installed cycle shack taper cuts, and screamin eagle on my 06 883L, and I accidently pulled the front wheel (slightly) off the ground when heading out of my driveway on the initial run.
Oh, but you will need to do a carb re-jet when you install those parts.
Old 12-25-2006, 04:45 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
As far as 'stock' torque and horsepower, here is some information I had saved;
"The 883 runs a 8.9-1 compression and can run on 87 octane fuel, while the 1200 has a compression ratio of 9.7-1 and requires 91+ octane fuel.
The 1200 also uses high flow cylinder heads from the Buell XB line, and cams from the 1200 Sport.
Factory horsepower and torque figures for the 883 are 53 HP at 6,000 RPM, and 51 LB-FT at 4,300 RPM.
Factory horsepower and torque figures for the 1200 are 70 HP at 6,000, and 79 LB-FT at 3,500 RPM."
Old 12-25-2006, 05:59 PM
Milt's Avatar
Milt
Milt is offline
My 07 manual says 91 octane for all models(sportster)
Old 12-26-2006, 01:20 PM
SportyPig's Avatar
SportyPig
ORIGINAL: Milt
That must be a change due to the Fuel Injection. My 06 manual says 87 octane for 883 and 91 for 1200. Just for the heck of it, I tried 91 octane in my 883. No difference in performance or gas milage. Just an increase in the price at the pump.
Old 12-26-2006, 01:37 PM
Milt's Avatar
Milt
Milt is offline
Must be the difference between bikes and cars,my car always gets better mileage And performance from premium.Always put it in the bike so......
kopirokok
Engine Mechanical Topics
07-16-2019 09:19 PM
Rollbar
10-22-2014 10:23 PM
jporges
03-28-2008 12:59 PM
Blue HD
03-19-2007 01:29 PM
chrism84
11-26-2006 10:04 PM
Quick Reply: sportster hp?
