06 sportster 1200 speedometer problems
Old 03-21-2012, 08:25 PM
ayers137's Avatar
ayers137
ayers137 is offline
Stage II
Default 06 sportster 1200 speedometer problems
i have an 06 sportster 1200 custom and the speedometer stopped working. The light and mileage reading isn't working either like theres no power going to it. The neutral and oil lights in the top half work though. Ive checked the fuses and they are good. Could it be a relay? Any ideas? thanks
Old 03-21-2012, 09:46 PM
Mich's Avatar
Mich
Mich is offline
My speedometer/odometer recently quit working but my light was still on. It turned out to be my VSS vehicle speed sensor, it had failed. Do your turn signals self cancel? that is another symptom of the vss failing.
Old 03-21-2012, 10:48 PM
Pvt Joker's Avatar
Pvt Joker
Pvt Joker is offline
I had the same thing happen with my roadster I bought in January. Speedo was completely dead when I bought it. No light, no odo, no start up or diagnostic mode. My turn signals worked properly. I check the 12v into the speedo, it was good. > Replaced speedo, works great.
I actually picked up two speedos, just by coincidence, so I've got a spare one.
Old 03-22-2012, 09:47 AM
ayers137's Avatar
ayers137
ayers137 is offline
Stage II
Yes my turn signals cancel. What did the new Speedo run you?
Old 03-22-2012, 03:04 PM
Pvt Joker's Avatar
Pvt Joker
I bought 2 of them on e b a y. <$100 ea
Old 08-30-2019, 11:11 AM
Nicholas Wright's Avatar
Nicholas Wright
Nicholas Wright is offline
Stage I
I have an 07 sportster 1200 xl and have the same issue. Speedometer doesn’t work at all, no needle twitch, odometer, lights, nothing. I’ve replaced the sensor, tried different speedometer, cleaned and checked the fuses, checked for any codes that might help and nothing worked. Still trying to find a solution that will get my speedometer up and running.
Old 07-31-2022, 09:47 AM
Oldbluesporty's Avatar
Oldbluesporty
Oldbluesporty is offline
Default Speedo not correct
04 883 with 1200 conversion. Earlier this year I had to replace entire bottom end after I finished that job. I was testing new motor. When I noticed my speedo was off by around 10mph according to my gps? Does anyone know why this could be?
jarredsj26
07-07-2019 08:14 PM
s42912c
Electrical/Lighting/Alarm
08-14-2017 06:58 PM
sputnicbmx88
08-06-2013 07:22 PM
ChefE
05-06-2008 11:17 PM
gdw70
09-13-2005 02:52 AM
Quick Reply: 06 sportster 1200 speedometer problems
