Sponsored by: Jekill and Hyde
What causes exhaust popping?
Old 03-18-2012, 07:26 AM
Timax52's Avatar
Timax52
Timax52 is offline
Default What causes exhaust popping?
I have just changed my old slip ons for new ones and am getting a bit of popping...what causes this and how do i fix it?
2000 RKC EFI
Many Thanks in advance
Old 03-18-2012, 07:38 AM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Put the words decel pop into the search feature above and you'll read about bike tuning, EFI remapping, lean conditions, etc.
I have some decel popping (mostly just gurgling) and actually love it.
Old 03-18-2012, 07:43 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Guessing you might have a leak @ pipe/header joint...did you use HT silicone on new pipes (i.e. liquid copper), new clamps & torque to speck?
Old 03-18-2012, 07:46 AM
RLE's Avatar
RLE
RLE is offline
Sounds like exhaust leak should be the first place to check.
Old 03-18-2012, 07:54 AM
Dew Me's Avatar
Dew Me
Dew Me is offline
Yeah, what Torquey said. With the slips you have to make other choices which you will learn from taking Torquey's advice but that isn't the whole reason for the decel. Question is whether your new slip-ons have baffles in them. No baffles, then that is your reason for decel right there. You want to stop it but don't want to quiet the bike get Big City Thunder baffles. If there are baffles in your new slip-ons then Iceman is probably right.
Old 03-18-2012, 08:05 AM
ynots's Avatar
ynots
ynots is offline
if its popping when you decelerate (decel popping) its caused by fuel burning in the exhaust manifold or header. if thats the case a proper tune will also cure the problem
Old 03-18-2012, 04:28 PM
Timax52's Avatar
Timax52
Timax52 is offline
Thanks guys, I did some research and found that decel popping is quite common and not harmful. I did use some copper grease and new clamps when fitting the slip ons and the bike now sounds like the devil with a toothache....I can live with the popping
Old 03-18-2012, 05:55 PM
djl's Avatar
djl
djl is offline
Received 2,029 Likes on 1,498 Posts
A properly tuned engine should not pop on decel. If the tune is right there will be no rich or lean conditions that will generate decel popping. That means that the popping is the result of intake or exhaust leaks. If those are sealed and the engine has a good tune, no popping. Some claim to like the popping but I am thinking they like it because they don't know how to get rid of it but would if they could. Decel popping is annoying; I hate it almost as much as I hate valve train noise but that's JMHO.
Whodattom
05-09-2014 08:08 AM
lennyb3us
05-02-2011 03:44 PM
Big_Al47
09-07-2010 10:27 AM
Foodog
02-19-2010 03:06 PM
bigheadted
09-18-2007 03:17 AM
Quick Reply: What causes exhaust popping?
