How to Replace rear drive belt
Old 03-09-2012, 03:23 PM
soft 02's Avatar
soft 02
soft 02 is offline
Originally Posted by Crash75
Chains were so much easier.... And what is an indy?
Independant mechanic=indy or non HD.
Old 03-09-2012, 06:35 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Also, Indy can stand for "a town that has lost it's 4 time MVP and Hall of Fame quarterback plus several of the receiver corp and probably the center".
Old 03-10-2012, 12:40 AM
jackstrr's Avatar
jackstrr
jackstrr is offline
Why would you want to replace it if its a good belt? I am not happy because mine is split and I am forced to replace it.
Old 03-10-2012, 01:16 AM
icufly's Avatar
icufly
icufly is offline
Not sure if they made the right decision or not. Only time will tell and I think it'll be quite a while before we know..
I changed the belt on my RKC. I hurt it towing a heavy trailer to Sturgis in 10, not too bad to do. If you're handy with tools and like doing that kind of stuff.. Good Luck
Old 03-10-2012, 06:58 AM
Terrabella's Avatar
Terrabella
Terrabella is offline
Independent Harley mechanic....sorry, question already answered.
Old 03-10-2012, 07:09 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Simpler if you are only changing the chain, but if you are changing the front sprocket you still must remove the primary, and it is even a dirtier job with a chain.
Old 03-10-2012, 07:47 AM
piasspj's Avatar
piasspj
piasspj is offline
But with a chain you get more practice because you do it more often.
Old 03-10-2012, 08:08 AM
trackadaptor's Avatar
trackadaptor
trackadaptor is offline
I blew my belt at 35k.....
First Belt Change - 6 hours - Second time 2 hours - look up my threads
All In Service Manual
1.) Remove Mufflers yes both
2.) Remove Rear Tire
3.) Remove Outer and Inner Primary's - Make sure you have a 150 pound
Torque wrench - to remove
Compensator / Stator nut
4.) Put small Jack under Tranny for Support - it's going to drop if ya don't
5.) Remove "Rear Fork" Swing Arm Bolt - listed as Rear Fork in Service
Manual it's a swing arm
6.) Remove Swing Arm - sorry Harley - Rear Fork
Replace: Belt , ALL Inner Primary Bolts/Seals - Gaskets , Replace Inner
Primary Bearing $ 30 these go out all the time, check Stator
NOTES: Use Blue lock tight on ALL nuts / Bolts - Torque to spec all bolts..
Compensator Nut - Install at 70ft.pounds trq. back off ,
tighten xxx Ft.pound trq. AS IN THE SERVICE MANUAL
Good time to consider:
SE Compensator , a better Stator while in there, Replace Fork / Swing Arms Bushings http://www.sta-bo.com/id2.html
Could have been a 1 person job, but a GF with a beer and a confident smile, "...I know you can do it honey,," helps a lot
Q103 (04-27-2020)
Old 03-10-2012, 09:33 AM
69cj's Avatar
69cj
69cj is offline
Did mine by myself. The hardest part was getting the swing arm and bushings in with out another set of hands. To be on the safe side plan on a full day and take your time.
Old 03-10-2012, 09:54 AM
Damascus's Avatar
Damascus
Damascus is offline
Originally Posted by Terrabella
After seeing the photos my screwdriver and pliers isn't going to get this job done.
Can't tell you how many times I've looked at my tool - and skill! - set with the same resignation.
I also weigh out that even if I can eventually do a job myself - over 14 weekends! - is it really worth the down time?
Ride safe,
Murph
Quick Reply: How to Replace rear drive belt
