06 dyna oil tran and primary capacity HELP.
Old 12-19-2006, 11:48 PM
wildfire's Avatar
wildfire
wildfire is offline
Default 06 dyna oil tran and primary capacity HELP.
I am on duty at the fire department. I tried asking my wife to read the owners manual and ell the capacities but she was unsuccessful. Could some on please tell me the capacities of the engine, tranny, and the primary? I am trying to pick up supplies in the morning. Thank you for all your help. Josh
Old 12-19-2006, 11:52 PM
KeithB's Avatar
KeithB
KeithB is offline
Big Kahuna HDF Member
Default RE: 06 dyna oil tran and primary capacity HELP.
engine 2.5, trans and primary less than 1 qt each
Old 12-19-2006, 11:54 PM
wildfire's Avatar
wildfire
wildfire is offline
Awesome!! life saver. I didnt want to drive 40 round trip to go home and check manual. Thank you again. Josh
Old 12-20-2006, 01:42 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
My service manual says 2.5 qts on engine re-fill. 1qt primary & 1qt trans.
Old 12-20-2006, 02:27 AM
clayman's Avatar
clayman
clayman is offline
I ve never been able to put the full quart into the trans or primary, i suggest put a little over 3/4 then cheque your levels then toup as needed.
Old 12-20-2006, 04:15 AM
AZ Rider's Avatar
AZ Rider
AZ Rider is offline
I usually use closer to 3 quarts for the engine. 1qt primary and 1 qt trans.
Old 12-20-2006, 10:12 AM
wildfire's Avatar
wildfire
wildfire is offline
Thank you to all that replied. Greatly appreciated this.
Old 12-22-2006, 06:04 AM
jimw411's Avatar
jimw411
jimw411 is offline
I'll put 2.5 in the engine, about 9/10ths of a quart in the primary, and if i let the trans drain a long time, it will take the full quart. My bike usually needs that other .5 a quart between oil changes to stay full. It uses about 1/4 of a quart every 1,000 miles
Bikz
05-15-2022 11:13 AM
kman42oo
02-15-2014 06:38 PM
oldngrey2
02-10-2014 12:43 PM
k2rmx.rob
03-14-2006 01:37 PM
Quick Reply: 06 dyna oil tran and primary capacity HELP.
