Electrical Problems????
Old 02-27-2012, 11:45 AM
c.woodyard's Avatar
c.woodyard
c.woodyard is offline
Stage I
Default Electrical Problems????
HELP... I've got a 2004 Road King Custom that seems to have some electrical problem. Starting last fall, it appeared that the battery was dieing, causing tougher starts. I charged the battery several times, but it was never really low. At times, while riding the little orange "engine" light would come on, then go off. (Same light that comes on when fuel injectors are priming.) Put it in storage for winter, so now I'm getting it ready for the season. Went out and put fresh fluids in, charged battery, started it... it ran for a few minutes, then the entire system shut down. No lights, nothing... I shut it all off, turned it back on...restarted. Same thing happened. OK...one friend says it sounds like the stator, and another says I've got a bare wire somewhere grounding out the whole thing... Any ideas? Also, I want to get a repair manual. Any information on what manual I should get (HD, Haynes, etc...) and a website to get a good deal on it... Thanks All, I appreciate it.
Old 02-27-2012, 11:52 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
H-D manual the rest are way too general.
The H-D has very good charging system diagnostics.
to check the electrical system you need a known good battery, other wise all the test results are skewed.
charge your battery with a real charger ( not a tender ) get it load tested at autozone.
If you get a jump and try running the bike with a dead battery, your charging system may be damaged as it works beyond capacity trying to charge the dead battery
if your battery passes, proceed. Other wise find a Deka battery dealer and get a new AGM battery.
from there you can test the stator output with a voltmeter, and check the regulator
there is an electrical tech board:
https://www.hdforums.com/forum/elect...-injection-55/
and here's a post:
https://www.hdforums.com/forum/8970068-post2.html
Mike
Old 02-27-2012, 11:56 AM
soft 02's Avatar
soft 02
soft 02 is offline
Yep. Load test battery and then we will talk.
Roni
07-08-2020 02:07 PM
stein79
Electrical/Lighting/Alarm
10-28-2016 08:55 AM
brentswth20
EVO
16
12-20-2014 11:16 AM
slipvayne9278
07-22-2011 12:39 PM
texasridr
EVO
25
09-01-2010 10:17 AM
Quick Reply: Electrical Problems????
