Charging a dead battery
Old 02-24-2012, 12:35 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
Default Charging a dead battery
I only have a tender that won't revive a dead bettery (safety feature, I guess).
I can boost the bike with a car (vehicle off, ignition on), but since the ground is covered in snow I wouldn't be able to ride it. Can I boost it that way off a car, let it idle for a bit, bring it in and put it on the tender?
I only need enough power to let the tender bring it back up.
Old 02-24-2012, 12:47 PM
grbrown's Avatar
grbrown
grbrown is offline
Take the battery off the bike, let it warm up indoors and your tender may do what is needed.
Old 02-24-2012, 12:56 PM
Ragnar Danneskjöld
Tender won't have anything to do with it, unfortunately.
Old 02-24-2012, 02:17 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,643 Likes on 1,133 Posts
Borrow a battery charger, use the 2A setting. I'm not sure I'd try to jump a motorcycle battery with a car's charging system. Too many amps could blow it up.
John
Old 02-24-2012, 02:40 PM
1CdnHD's Avatar
1CdnHD
1CdnHD is offline
The Deltran "Battery Tender" needs 4.5 volts to trigger the charger, you can put it on a generic charger to get it up to there, then use the Tender to get it healthy.
You'd have to get your bike up to at least 1200 RPM to charge, idle wont' do it.
Old 02-24-2012, 02:42 PM
Ragnar Danneskjöld
Hm...well, I'll try to see if someone has a battery charger I can borrow. If not, I'll jump it when it gets warmer out.
Old 02-24-2012, 02:43 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
You could always take it out and take it to Advance Auto to charge for free.
Old 02-24-2012, 02:48 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
as long as its not frozen you can jump the battery with a car, or just take it out of the bike and put jumper cables on it and hook it to the car battery for some few minutes, just to get the voltage up enough for charger to take over....you can jump it right on the bike if you want, but its hard to get the cables on without shorting something with the cables.....its just like jumping a car....
Old 02-24-2012, 02:53 PM
Ragnar Danneskjöld
I was wondering if that were possible.
Old 02-24-2012, 02:58 PM
hig4s's Avatar
hig4s
hig4s is offline
A battery that is that low and has probably been frozen, might not come back.
Quick Reply: Charging a dead battery
