Max RPM setting 103 modified?
Old 02-22-2012, 09:39 AM
WIHD55's Avatar
WIHD55
WIHD55 is offline
Default Max RPM setting 103 modified?
Curious, what rpm do you have your rev limiter set at? With what setup?
I have stock springs/heads with a S&S 551 cam (SE255 very similar) 2011 103. My bike makes all of it's torque/HP 2200-4500. I can't really see a need to bump the rev limiter. If I do, maybe a few hundred.
What is a safe max RPM on the 103 in your opinion?
Old 02-22-2012, 09:49 AM
djl's Avatar
djl
djl is online now
Received 2,054 Likes on 1,512 Posts
My 95" B motor and my 107" A motor are both set at 6200 and I hit it on occassion.
Old 02-22-2012, 10:30 AM
ocezam's Avatar
ocezam
ocezam is offline
I can't imagine you'd be bumping the stock rev limiter very often with those cams. Having said that, my limiter is set at 6200. My cams aren't what you'd want at that rpm either. I'm never over 5500 in real life and rarely over 5K.
NorCalFBLO's Avatar
NorCalFBLO
NorCalFBLO is offline
2010 fatboy Lo with 103, 10:5:1, 259E, no head work but new springs and my rev limiter is set at 6200. I also hit it it occasionally as it get there fast in 1st and 2nd gears.
Old 02-22-2012, 10:33 AM
ocezam's Avatar
ocezam
ocezam is offline
Yeah but your talking pretty serious compression/cams and high performance springs. Bet it's a fun ride!
Old 02-22-2012, 10:46 AM
frog13's Avatar
frog13
frog13 is offline
2012 Street Glide, Woods TW-555 Cams, rev limiter set at 6200 and can find it in the first five, pulling power all the way, very quick in the first three. I wouldn't want to set it any higher than that, though.
Old 02-22-2012, 10:48 AM
Mntsnow's Avatar
Mntsnow
Mntsnow is offline
6200 on my 103 Stage IV build
Ryan o
04-04-2018 01:34 AM
jpdeville
Engine Mechanical Topics
08-06-2017 02:45 PM
Ahhnuld
2014-2023 Touring Models
17
05-24-2016 05:33 PM
Cascade
18
05-31-2015 10:28 AM
lkr0
11-03-2007 10:22 PM
Quick Reply: Max RPM setting 103 modified?
