What is the best bolt in cam for '97 80 ci evo?
Old 02-18-2012, 10:10 PM
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
An Andrews cam is a good way to go because you can use stock valve springs...The other cam options with more lift require replacing the springs which means you must remove the heads...You can't go wrong with an Andrews Cam!
Old 02-19-2012, 11:26 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I choose the EV27 simply because so many on this board loved it. My deal was this... there is a known problem with the Evo cam bearing. It has a long history of failing between 30-50k. Well, if I have to have a shop pull the cone and remove the cam anyways, why not spend a few extra bucks and put a better than stock cam in. The EV27 seems to pull hard and it works excellent with my basic stage one setup. With just those mods I can run with a 1200 Sporty and stock twin cams. I got a used one so I didn't even have to lay out the $125 for a new one. I'm pretty happy.
Old 02-19-2012, 01:37 PM
shineola's Avatar
shineola
shineola is offline
hq-0024
crane 310
andrews ev-3
Old 02-19-2012, 03:13 PM
FXD_One's Avatar
FXD_One
FXD_One is offline
+1 on this, did the exact same thing after asking for suggestions on this board.
Old 02-19-2012, 06:52 PM
bigdave367's Avatar
bigdave367
bigdave367 is offline
1st Gear
Thanks everyone!!! I have heard the ev-27 was a good overall cam. I bought a while back a Crane 316-2 cam. It is a .490 lift and all the other specs are relatively close to those on the ev-27. I also have crane fully adjustable pushrods to simplify the install, just got to have it done and have the carb installed and tuned with the cam.
Again, thanks to all who responded!!!
Old 02-19-2012, 06:55 PM
shineola's Avatar
shineola
shineola is offline
the crane will be lazy on the bottom end if you don't add some compression to it. The intake closes a little late for a stock evo I feel
Old 02-19-2012, 07:07 PM
bigdave367's Avatar
bigdave367
1st Gear
thanks! I need to look at those cam card numbers again!!
Old 02-19-2012, 11:59 PM
nytryder's Avatar
nytryder
nytryder is offline
+1 on that.
mpescatori
EVO
10-08-2016 07:34 AM
eddieflyer
Softail Pictures
10-14-2008 03:03 PM
jergy77
Exhaust System Topics
04-30-2008 10:04 PM
beeoh
10-18-2007 07:16 AM
Blown 331
EVO
15
02-23-2007 08:53 AM
Quick Reply: What is the best bolt in cam for '97 80 ci evo?
