01 FXDL Turn Signal wiring
Old 02-15-2012, 03:52 PM
justmealwatts's Avatar
justmealwatts
justmealwatts is offline
Thumbs up 01 FXDL Turn Signal wiring
I'm new to the Dyna family. As of this moment, I do not have a service manual for my year bike but I have a few questions.
I'm in the process of doing a few things to my 2001 FXDL. Moving the front turn signals down to the fork tubes was on my list today. I removed the gas tank to make things easier and to clean up a little. I figure that I'd just unplug the turn signal wiring harness, etc... but the wires just go into the neck in the frame and there isn't a plug to work with. The same goes for the handlebar controls. The bike is stock but the wires have been cut and soldered at some point about 6 inches out of the neck.
I know that it's possible for the connectors to be shoved down in that little hole in the neck but I'm not going to start jerking on the wires until I get some advice. I have a wiring diagram and it's showing a 6 pin connector for the turn signals but it's obviously not visible.
Thanks!!!
Old 02-15-2012, 05:30 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Before you yank on the wires, you will need to remove the back wheel, yes the back wheel, then you will see a plastic square plug about 2x2 in size , remove that , inside you will see your harness, it may be tied up with a plastic tie wrap, remove the tiewrap, now you can pull the harness out of the neck, it helps if you have someone push on the harness as you pull it forward, i have attached a pic of what this looks like.
Old 02-15-2012, 09:11 PM
justmealwatts
Thumbs up
Thanks Robtarra39,
What an introduction into Dyna wiring on my bike. The turn signal and handlebar control connectors are down in the frame. The wiring harness was not pliable and being folded up for 10 years, I can tell you that it didn't just flop out. I left the tire on because I thought that I wasn't going to struggle as much as I did. Witht he tire being off, I can see the benefits. At least I learned something tonight but I wish that the connectors were located under the tank for easier access. Maybe things will go smoother after I do it about 10 times. Thanks!!!
Old 02-16-2012, 05:20 PM
Robtarra39's Avatar
Robtarra39
Glad it worked out for you.
Old 02-16-2012, 06:19 PM
PhotoRider's Avatar
PhotoRider
PhotoRider is offline
interesting, by 2000 service manual doesn't say to remove the wheel, just the belt guard to gain access (course I have a FXDX, but the manual covers the FXDL).
I pulled mine out to install t/s mirrors. It took a little effort to wiggle them out. Get them back in was the fun part
Old 08-10-2012, 09:17 PM
OldTyme's Avatar
OldTyme
OldTyme is offline
If I can bump this post w/ a similar question.
I was (unsuccessfully) trying to mount new bars....now my front signals dont work, the back ones do.
Are the front turn signal wires really ran all the way to the back of the bike?
Thanks
(edit: they were unplugged @ the connector that was inside the frame. geesh HD. nice place for that one. lol)
Old 07-09-2020, 05:17 PM
Isreal Long's Avatar
Isreal Long
Isreal Long is offline
Stage I
Thanks
hey I know this is an old post but I just had the exact same problem and I was stumped. Thank God for forums!
Cullmanco
Electrical/Lighting/Alarm
02-21-2012 06:04 AM
BigLowRider
06-06-2009 07:52 PM
2005sporty
05-13-2008 04:45 PM
baxter
04-23-2007 07:48 PM
Frankster69
05-13-2006 11:35 PM
Quick Reply: 01 FXDL Turn Signal wiring
