Trailer set-up
Old 12-17-2006, 12:08 PM
cozybay's Avatar
cozybay
cozybay is offline
1st Gear
Default Trailer set-up
I'm setting up a new 16 ft enclosed trailer for my roadking, any info on tie downs, placements and good ideas.
would like to hear. Thank's
Old 12-17-2006, 12:14 PM
100thRK's Avatar
100thRK
100thRK is offline
Default RE: Trailer set-up
I assume at 16ft it is a double axle? There are many schools of thought on this. Commonalities are weight over the axles and bikes staggered if using for more than one bike. I like the side wall mounted adjustable tie downs plus floor mounted d-rings and the ride in and get off chocks. This link has lots of info. Motorcycle Trailers
Old 12-17-2006, 12:18 PM
Faulkner's Avatar
Faulkner
Faulkner is offline
Make sure you put at least four tie downs for the front and two for the back, and install a front wheel chock. You want to have six different contact points on the bike, you don't want two straps going to the same place.
On one trip this summer I had a strap fail. Even though I'd used all new straps, one of the front straps malfunctioned before I got very far and if I'd not had the extra strap on the front the bike would have flopped around for a 100 miles. I use the rear straps just to keep the rear end from shifting from side to side.
Old 12-17-2006, 08:14 PM
MCSarge's Avatar
MCSarge
MCSarge is offline
I carry mine on a flat bed trailer with a rubber mat to keep the tires from sliding and I have tie down rings to secure it at the four corners. Carried 100 miles over the worst highway in MI and it never moved.
Old 12-17-2006, 08:22 PM
Qball's Avatar
Qball
Qball is offline
7 X 14 enclosed trailer. recessed d'rings, Condor wheel chocks. Have bikes staggered, tried to put over the dual axles. if I pull 1 bike I put it in the rear position. Also have a weight distributing hitch and sway bar. Place straps around forks, engine guards and rear floorboard brackets.
Old 12-17-2006, 08:51 PM
rdam's Avatar
rdam
rdam is offline
I use Bike Pro chocks. 2 front tie-downs to the engine guard. 2 rear to the passenger floorboard mount. Over 4000 miles of trouble free trailering.
Old 12-17-2006, 10:12 PM
LimeNine9r's Avatar
LimeNine9r
LimeNine9r is offline
I have a 7x16 "Haul'inASS" brand cargo trailer,
bought "e-track" and pitbull chocks. See attached photo's
What I like the best is that the e-track lets you place
any bike anywhere you want, you're not limited to where
it's gonna haft to sit.
I think I spent close to $500 for the e-track and snap rings
Hauls (4) sport bikes perfectly, I put the longer, heavier
Harlies in the front 2 spots when they get to play with us.
[IMG]local://upfiles/17429/A7A3A8FFC15E42D09859FB068CE5B720.jpg[/IMG]
[IMG]local://upfiles/17429/3DEA53DAADF04985864A32646122F489.jpg[/IMG]
[IMG]local://upfiles/17429/F7492E151F094C5395A9E72923AFBA33.jpg[/IMG]
[IMG]local://upfiles/17429/C0A88FC919E94F43879804FE57A56E56.jpg[/IMG]
[IMG]local://upfiles/17429/90A4BF23F93B48589BD075E5A7586AA3.jpg[/IMG]
Old 12-17-2006, 10:39 PM
toyrider's Avatar
toyrider
toyrider is offline
I use the same e-track system as LimeNine9r and also have a Haulin trailer. I like the condor wheel chocks. RIde in, get off, tie down and no worries
Old 12-18-2006, 05:51 PM
Budz's Avatar
Budz
Budz is offline
I have a 16' X 6' trailer although it is a utility trailer (open). Unless you plan on haulin' a lot more than a couple bikes I'd think a little smaller. To me a 12' would be perfect. Costs less, easier to pull and store, etc. If you do toll roads, the number of axles matters as well. Bigger isn't always better.
RonRock
02-05-2012 01:01 PM
harley-jones
03-31-2010 10:17 AM
jmbaker3
02-04-2010 09:16 PM
promet1
01-08-2008 10:10 AM
Qball
09-14-2005 01:26 AM
Quick Reply: Trailer set-up
