Points wiring and tach...
Old 02-13-2012, 03:09 PM
trip59's Avatar
trip59
trip59 is offline
Default Points wiring and tach...
MM to EFI conversion on my 98RK is nearly done. I went points, but it's been a couple decades since I wired one. Can someone verify I got this right;
Power to one side of coil via relay (relay uses start/run switch to engage), wire from the other side of the coil to points. Correct, yes?
Now, with a modern tach, Can I run a wire from one side to the tach, and which side or do I need some sort of circuit to convert?
Sal C
02-18-2016 12:36 AM
bolillo57
06-17-2013 04:05 AM
bellestarr
Shovelhead
11-10-2011 09:01 AM
bolillo57
06-08-2011 07:37 PM
90ssharley
03-15-2009 12:03 PM
Quick Reply: Points wiring and tach...
