Avon Air Cushioned Grip Removal
Old 02-13-2012, 12:35 PM
casique's Avatar
casique
casique is offline
Default Avon Air Cushioned Grip Removal
A lot of information on installing grips. How about removing the glued on Avon grips with the cushion rings and hard plastic inside?
Old 02-13-2012, 12:44 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
Do you want to use them again?
If not ..... channel locks and a twisting motion.
Old 02-13-2012, 02:10 PM
Ride my Seesaw's Avatar
Ride my Seesaw
Ride my Seesaw is offline
Received 1,562 Likes on 731 Posts
Slide a screwdriver up under the rubber then spray some WD-40 in there. Wait a few minutes then slowly work the screwdriver around the grip, add more WD-40 as needed. Position a rag over any part of the bike that might get dripped on. Works like a charm.
Old 02-13-2012, 03:08 PM
JohnScrip's Avatar
JohnScrip
JohnScrip is offline
They use that "tape" adhesive sheet, right? Easy as ripping glue? Do peole recommend not using the sheet and sticking (no pun intended) with traditional adhesives when installing instead?
Curious - I'm tossing around the idea of the Avon (Boss Performance? Something like that) grips myself.
Old 02-13-2012, 03:13 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
WD40 works eventually, but not very well. If you have to put something in there to dissolve the glue you should use something stronger, like gas or a solvent. Just watch your paint. Try a hair dryer to soften the glue then twist it off. I have never tried it but I hear it works, worth a shot.
Old 02-13-2012, 03:22 PM
hougz79's Avatar
hougz79
hougz79 is offline
That's what I would do.
Old 02-13-2012, 03:25 PM
casique's Avatar
casique
casique is offline
Great ideas thanks!
Old 02-13-2012, 03:29 PM
mrfikser's Avatar
mrfikser
mrfikser is offline
I heard once about a guy who used air blown in around the opening to break it loose....I have used a piece of coat hanger bent into a capitol "T" shape a pushing the bottom part of the "T" in between the grip and the handlebar all the way to the end of the handlebars and twisting to top part like you are opening a can of sardines ...the coat hanger should slowly walk around the handlebar breaking the grip loose, after you get about half way you can usually just give the grip a firm twist and it will break loose...I don't know if this will work with yours, but it works on stock grips...
Old 02-13-2012, 04:26 PM
troop's Avatar
troop
troop is offline
I just twisted/pulled until the left grip broke loose. Avon will send you new tape wrap upon request for re-using. Don't destroy the grip....
Old 02-13-2012, 07:03 PM
casique's Avatar
casique
casique is offline
Troop, did you use a set of pliers/channel locks to twist and turn?
Quick Reply: Avon Air Cushioned Grip Removal
