Single or Dual axel trailer for bike ??
Old 02-13-2012, 05:32 AM
timberland's Avatar
timberland
timberland is offline
Location: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Originally Posted by Bingee
A harley can't weigh more than 900 lbs. A tandem is overkill even for an enclosed trailer. Also a single axle does NOT bounce more than a tandem. Nor does it sway more. And it doesn't add anything to safety either. But it does add to the cost. You'll need new tires every 5 to 6 years regardless of mleage. Two tires are cheaper than four tires. The only reason for two axles is to carry more weight. Much more weight.
^^^ Nope.
Get a dual axle, they DO ride smoother, the singles DO have a tendency to sway more, a tandem DOES add to the safety. You'll need new tires every 5-6 years with any trailer. I have a 12' Haulmark low hauler, it's an excellent towing trailer...and yes it does have tandem axles and needs it.
Old 02-13-2012, 05:35 PM
ucommbxny's Avatar
ucommbxny
ucommbxny is offline
i hav a single axle 6x10 trailer
Attached Thumbnails Single or Dual axel trailer  for bike ??-trailer-for-motorcycle-005.jpg
Old 02-14-2012, 07:26 PM
rlaf75's Avatar
rlaf75
rlaf75 is offline
i have a 7x10 closed single axle with brake and ive never had a problem hauling two bikes. it went to myrtle beach and back a few years ago with 2 bikes and a buddy is taking it to sturgis this year with 2 bikes in it.
Old 02-14-2012, 07:42 PM
ultra_classic's Avatar
ultra_classic
ultra_classic is offline
Second that, Plus here in Ontario in the "Great White North" you need an annual Safety inspection performed to renew your yellow safety sticker with tandem axle's Costing anywhere from $75-$189. Note: some people skip this
I as at the bike show here last weekend and looked at a 8x12 single for 3995.00 but passed on it for now
Old 02-14-2012, 08:00 PM
roborob's Avatar
roborob
roborob is offline
Cmon wildviking your not stuck getting a trailer, think of it as MORE OPTIONS.I have a dual axle enclosed trailer , I dont use it often but its there. It has other duties too. Dont sound apolgetic about a trailer. congrats.
Old 02-14-2012, 08:13 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
I go with dual axles and electric brakes for the handling and safety. I will only tow with weight equalizing hitch and sway bars. I have towed in the winds across the Dakotas and didn't even notice.
The best advice that I could offer is to understand the weight loading requirements of a trailer. 60% of the load in a single axle should be ahead of the axle and 70% ahead with dual axles.
Much of the swaying of any trailer is due to how it is loaded. I have been towing all sorts of trailers since the 70's and learned many lessons.
This is my current enclosed trailer a Haulmark 8.5 by 20 to haul three bikes and living accommodations.
Old 02-14-2012, 08:16 PM
littlebear's Avatar
littlebear
littlebear is offline
My single axle work just fine,pulled behind my 5th wheel, No Problems
Old 02-14-2012, 08:19 PM
michaelnmississippi's Avatar
michaelnmississippi
michaelnmississippi is offline
Double axle enclosed is great for bike gear storage. As well as hauling the bikes. I love trailering my bike on long trips to the mountains , at night when it rains I have a second option for transportation. Call me a puss if you like but at 53 I have chosen comfort over macho
Old 02-14-2012, 08:20 PM
09FLHT's Avatar
09FLHT
09FLHT is offline
Originally Posted by wildviking
I know I know but we want to take the bike behind the motorhome and do some traveling .. Would love to just be on the bike but hard to fit the dogs on a bike.. So stuck with getting a trailer .. So should I get a single or dual axle enclosed trailer????
Get the dual axle and get it a little longer than you need for the bike. You can use the front of the trailer for extra storage. Tools, build a bench, have a nice little portable shop.
Old 02-14-2012, 08:24 PM
peippert's Avatar
peippert
peippert is offline
I have a Haulmark low hauler, dual axle with rubber torsion axles. A single definitely pulls easier. I got too good a deal to pass this Haulmark up, but it has a constant chop with the dual torsion axles. I use a weight equalizing hitch just to try to damp that out of it. Someone else had it right - sway is all in how it's loaded - insufficient tongue weight and the trailer will yank a vehicle all over the place. Only get dual axles if you need to haul weight, otherwise a single is just fine.
Quick Reply: Single or Dual axel trailer for bike ??
