Clutch/Brake lever replacement.
Old 02-06-2012, 05:59 PM
Berts's Avatar
Berts
Berts is offline
Default Clutch/Brake lever replacement.
So I scratched up my Clutch lever pretty bad and want to replace it. The only problem is that if I buy from Harley it's $100 for both the clutch and brake lever. I was wondering if anyone knew of anywhere I could get a stock 2012 Iron clutch lever for cheap or if you have any suggestions on some cool levers.
Also, are they hard to install? I have limited mechanical knowledge.
Old 02-06-2012, 07:52 PM
VirgeB's Avatar
VirgeB
VirgeB is offline
Tons of places to include ebay. All you have to do is search.
Old 02-06-2012, 10:03 PM
MrCookie's Avatar
MrCookie
MrCookie is offline
I like the choices at debrix.com
Old 02-07-2012, 09:37 AM
emperor wurm's Avatar
emperor wurm
emperor wurm is offline
ebay or craigslist
Old 02-07-2012, 09:50 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
If you don't know what you're doing, the brake lever is quite tricky. To begin with, you need to put a piece of cardboard between the brake lever and the housing before you open up the switch housing. If you don't, the brake light switch will break.
Old 02-07-2012, 10:40 AM
pointdogg48's Avatar
pointdogg48
pointdogg48 is offline
dood, i just bought the one from drag specialties for $30 for brake + clutch. its an exact match to the stock HD part. I swapped out my clutch lever last night which was easy.
Old 04-20-2012, 02:58 PM
jerryw618's Avatar
jerryw618
jerryw618 is offline
Any more info on changeing the brake lever ??? im about to change the levers and dont want to bust aswitch
Old 04-20-2012, 03:25 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,631 Likes on 1,125 Posts
I had to remove my throttle and switch housings when my bike got knocked over and it pinched a wire to my start/run/stop switch. Don't really recall any problem with the brake switch. There is a plunger like piece the brake lever fits to, as I recall. Of course, my bike is a 1991 and they may have changed how it goes together over the years.
John
Old 04-20-2012, 03:49 PM
edgeofinsanity's Avatar
edgeofinsanity
edgeofinsanity is offline
Like already posted, clutch lever is easy. I rerouted my clutch cable due to installing higher bars, and took the lever off so I could just run it through the front forks, rather than remove the headlight. From what I remember:
For the clutch side, you'll need a snap ring tool, or some small needlenose pliers and a new snap ring. Start by sliding up the rubber cover on the clutch cable, near the frame, it should be clipped to the frame with some wires. Loosen the locknut under the cover and adjust the cable putting in as much slack as you can. The lever is attached to the controls with a pin, which has that snapring on the underside. Remove that snapring, and the pin comes out, then just pull your loosened cable through the control housing. There is a small black "clip" looking thing on the underside of the clutch lever, it's there so the lever doesn't vibrate. Take it off (single black phillips head screw) and put it on the new lever. Attach the cable to the new lever and put it back together, then readjust the clutch cable (1/16" to 1/8" slack at the lever).
Not sure on the brake side.
Old 04-20-2012, 07:20 PM
jerryw618's Avatar
jerryw618
I have all the tools and ive done clutch lever and clutch cable replacements , i am just not sure where the little brake light switch is on the brake lever to put tha cardboard in ? i guess ill have too drive up too storage and dig out my shop manuals
Quick Reply: Clutch/Brake lever replacement.
